Mini Cooper R50 R52 R5
Revision as of 15:36, 6 May 2016 by Brentp (talk | contribs)
Status
In development / verification phase. The Mini Cooper ECU and instrument cluster electronics are based on BMW running gear, so this integration is adapted from the BMW E46 instructions.
Channels available
This integration will offer the following channels (to be verified)
  • Throttle Position (TPS)
  • Engine Temperature (EngineTemp)
  • Oil Temperature (OilTemp)
  • RPM (RPM)
  • Steering Angle (Steering)
  • Brake Switch (BrakeSw)
  • Brake Pressure (Brake)
  • Left front wheel speed (LFWheelSpd)
  • Right front wheel speed (RFWheelSpd)
  • Left Rear Wheel Speed (LRWheelSpd)
  • Right Rear Wheel Speed (RRWheelSpd)
  • Gearbox Temperature (GearboxTmp)
  • Exterior Temperature (ExtTmp)
Things you'll need
  • PosiTap insulation piercing taps (22 gauge)
  • Android tablet
  • 2002-2006 Mini Cooper (R50, R52, R53)
Estimated Time
2-3 hours, depending on level of wiring experience. The most time consuming part is locating and splicing the CAN, power and groud wires into the RJ45 cable.
CAN wires
  • (VERIFY) Yellow/Red = CAN+ (high)
  • (VERIFY) Yellow/Brown = CAN- (low)
They are a twisted pair in or attached to the main wiring harness under the driver's side dash above the dead pedal. The wires need to be tapped, not cut.
Tapping CAN wires
To tap into the wires, you'll first need to unravel the wire as the CAN+/CAN- pair are tightly wound. You'll want to have enough room for 2 fingers in between the wires.
Tapping the wires via Posi-taps (recommended) is easy. Pull the top off the Positap, place the wire in it and tighten.
Power and ground wiring
Best option OBD-II port power
Using the same cable used for the CAN bus connection you can tap into power on the OBD-II port, for a clean 4 wire connection
Mini Cooper power, ground and CAN bus connections to RaceCapture/Pro
Connection Mini Cooper RaceCapture/Pro (RJ45 cable)
+12v (VERIFY) Yellow-Red (OBD-II connector) Brown
Ground (VERIFY) Brown (OBD-II connector) Orange/White
CAN High (VERIFY) Yellow/Red Orange
CAN Low (VERIFY) Yellow/Brown Green/White
CAN Bus connection
  • Orange: CAN1 High
  • Green/white: CAN1 Low
  • Brown: Power
  • Orange/white: Ground
  • Note: Verify your RJ45 cable has EIA T568B printed on the jacket; this will ensure the color codes match.
Use the following diagram:
Configure RaceCapture/Pro
Quick Start configuration
Download: Mini Cooper starter configuration (right-click, save-as)
To complete your configuration for lap timing and live streaming to Podium:
Manual Setup
If you already have an existing, customized configuration, follow these steps to add Mini Cooper CAN bus integration.
  • Rate is 500kb/s
  • Do not enable OBD-II channels.
Add this script to the Scripting section:
Script
--This example configured for Mini Cooper CAN
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
--format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units])
tempId = addChannel("EngineTemp", 1, 0, 0, 255, "F")
oilTempId = addChannel("OilTemp", 1, 0, 0, 255, "F")
steerId = addChannel("Steering", 10, 0, -360, 360, "Deg.")
brakeId = addChannel("BrakeSw", 10, 0, 0, 1)
brakePressId = addChannel("Brake", 10, 0, 0, 255, "Bar")
clutchId = addChannel("Clutch", 10, 0, 0, 1)
lfWheelId = addChannel("LFWheelSpd", 10, 0, 0, 200, "MPH")
rfWheelId = addChannel("RFWheelSpd", 10, 0, 0, 200, "MPH")
lrWheelId = addChannel("LRWheelSpd", 10, 0, 0, 200, "MPH")
rrWheelId = addChannel("RRWheelSpd", 10, 0, 0, 200, "MPH")
gearTempId = addChannel("GearboxTmp", 10, 0, 0, 400, "F")
fuelId = addChannel("Fuel", 1, 0, 0, 100, "%")
extTempId = addChannel("ExtTemp", 1, 0, 0, 120,"F")
--Convert C to F
function toF(value)
 return value * 1.8 + 32
--TPS, correct your throttle here for true 100%
function tpsFilter(value)
 return value + 0.0
function rpmFilter(value)
 return value
function brakeFilter(value)
 return bit.rshift(bit.band(value, 0x10), 4)
function clutchFilter(value)
 return bit.band(value, 0x01)
function processWheel(id, data, offset)
  --wheel speed is 13 bits long, little endian
  --low byte high byte
  --76543210 76543210
  --11111111 11111XXX
  local highByte = bit.band(data[offset + 2], 0x1F)
  local lowByte = data[offset + 1]
  local value = highByte * 256 + lowByte
  value = value * 0.0625
  --convert to MPH. comment to keep KPH
  value = value * 0.621371
  setChannel(id, value)
function processSteering(data)
    local steer = 0
    if data[2] > 127 then
    else
      steer = (data[2]*256)+data[1]
function fuelFilter(value)
  --adjust for 7 bit value
  value = bit.band(value, 0x7F)
  --convert liters to %
  return value / 0.48
function extTempFilter(value)
  local temp = bit.band(value, 0x7F)
  if value > 127 then
    temp = -1 * temp
  temp = toF(temp)
  return temp
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>,
--                                   <adder>, [filter])
CAN_map = {
[496] = function(data) processWheel(lfWheelId, data, 0)
                       processWheel(rfWheelId, data, 2)
                       processWheel(lrWheelId, data, 4)
                       processWheel(rrWheelId, data, 6)
        end,
[339] = function(data) map_chan(brakeId, data, 0, 1, 1, 0, brakeFilter) end,
[504] = function(data) map_chan(brakePressId, data, 2, 1, 1, 0) end,
[809] = function(data) map_chan(tpsId, data, 5, 1 , 0.392156863, 0, tpsFilter)
                       map_chan(tempId, data, 1, 1, 0.75, -48, toF)
                       map_chan(clutchId, data, 3, 1, 1, 0, clutchFilter)
        end,
[1083] = function(data) map_chan(gearTempId, data, 0, 1, 1, -55, toF) end,
[790]  = function(data) map_chan(rpmId, data, 2, 2, 0.15625, 0, rpmFilter) end,
[501]  = function (data) processSteering(data) end,
[1555] = function (data) map_chan(fuelId, data, 2, 1, 1, 0, fuelFilter) end,
[1557] = function (data) map_chan(extTempId, data, 3, 1, 1, 0, extTempFilter) end
    processCAN(CAN_chan)
function processCAN(chan)
    local msg = 0
    repeat
        local id, e, data = rxCAN(chan, 0)
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
        msg = msg + 1
    until id == nil or msg > 100
    if offset + len > #data then return end
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
 local cv = value * mult + add
    setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
Test!
Real-Time Telemetry
Just 4 wires - Power, Ground, CAN+ and CAN- is needed to stream tons of data to Podium for monitoring engine, driver and suspension performance!
  • If you don't see any data, verify all connections and splices.
  • If everything is connected connect your laptop to RaceCapture/Pro, open the RaceCapture/App, go to the Scripting section, set Logging Level to debug and select 'Poll logfile'. Check the output for any errors relating to the Lua Script.
  • If you're copying in the script file, ensure any existing script is erased first, do not append the script text to the existing script.
