AutomaticCameraControl
GoPro WiFi control
Lua Script
Customization
You will need to edit the following fields at the minimum, located at the top of the script
Required
- GoPro WiFi password: Specify the WiFi password used for the GoPro WiFi adapter
- GoPro SSID: Specify the GoPro WiFi network name (SSID)
Optional
- Start trigger Speed: Change this if you want it different from the default start trigger.
- Stop trigger Speed: Change this if you want it different from the default stop trigger. Ensure this is less than the start trigger
goproPwd = '12345678'
goproSsid = 'aslhero1'
goproStart = 10
goproStop = 5
--How fast we check, in Hz
tickRate = 10
debug = 0
--DO NOT EDIT BELOW
port = 4
--indicates wifiStatus
wifiStatus = 0
lastInitTime = 0
initTimeout = 20000
function logMsg(msg)
println('[GoProWiFi] ' ..msg)
function sendCrlf()
writeCSer(port, 13)
writeCSer(port, 10)
function sendRaw(val)
for i=1, #val do
function sendAt(val)
sendRaw(val)
sendCrlf()
function toInt(val)
return string.sub(val, 1, -3)
function httpGet(url)
sleep(500)
sleep(100)
sendRaw(get)
sleep(100)
sendAt("AT+CIPCLOSE")
function startGoPro()
logMsg('start GoPro')
sendGoProShutter('01')
function stopGoPro()
logMsg('stop GoPro')
sendGoProShutter('00')
recording = 0
function initWiFi()
logMsg('initializing')
sendAt('AT+RST')
sleep(2000)
sendAt('AT+CWMODE_CUR=1')
sleep(1000)
wifiStatus = 1
function processIncoming()
wifiStatus = 2
wifiStatus = 3
logMsg('ready for GoPro')
function checkGoPro()
if wifiStatus == 0 then
initWiFi()
lastInitTime = getUptime()
return
wifiStatus = 0
processIncoming()
if wifiStatus ~= 3 then
return
trigger = getGpsSpeed()
startGoPro()
recording = 1
stopGoPro()
recording = 0
checkGoPro()
