AIM SmartyCam CAN
Connecting to the AIM system
AIM cable connection mapping | ||||||
Connection | AIM Pin (Binder 702) | RaceCapture/Pro Pin (EIA-T568B Ethernet cable) | ||||
CAN High | 1 (White) | 2 (Orange) | ||||
CAN Low | 4 (Blue) | 3 (Green / White) | ||||
Ground | 2 (Brown) | 1 (Orange / White) | ||||
VBExt | 3 | N/C (Do not connect) |
Note
- RaceCapture/Pro provides a 12v input pin (Pin 8) on the RJ45 connector, which has a common connection to the 12v input of the RaceCapture/Pro terminal block.
- This pin is rated at 1A max. We do not recommend using this pin to supply power to the AIM Smarty CAM.
Available Channels
BMW E46 (including M3) | ||||||
AIM Channel Name | RaceCapture channel name | |||||
RPM | RPM | |||||
Gear | Gear | |||||
WaterTemp | EngineTemp | |||||
Oil Press | OilPress | |||||
Oil Temp | OilTemp | |||||
Throttle Position | TPS | |||||
Head Temp | HeadTemp | |||||
Exhaust Temp | EGT | |||||
Brake Pos (channel 1) | BrakePos | |||||
Clutch Pos (channel 2) | Clutch | |||||
Brake Press (channel 3) | Brake | |||||
Steer Position (channel 4) | Steering | |||||
Lambda (channel 5) | Lambda | |||||
FuelLevel | FuelLevel |
Integration Cable
Build your own
Get a pre-made cable
[[Image:add_to_cart.png|link=https://www.autosportlabs.com/product/aim-dashboard-telemetry-cable/]
AIM Integration Script
- Note - ensure any existing script is removed before copying in the AIM integration script.
--AIM Smarty Cam Stream For Race Capture --how frequently we poll for CAN messages tickRate = 30 --the CAN baud rate CAN_baud = 1000000 --CAN channel to listen on. 0=first CAN channel, 1=second CAN_chan = 0 --1 for Big Endian (MSB) mode; 0 for Little Endian mode (LSB) be_mode = 0 --add your virtual channels here tpsId = addChannel("TPS", 10, 0, 0, 100, "%") tempId = addChannel("EngineTemp", 1, 0, 0, 120, 'C') oilTempId = addChannel("OilTemp", 1, 0, 0, 170, 'C') rpmId = addChannel("RPM", 10, 0, 0, 10000, 'RPM') oilPresId = addChannel("OilPress", 10, 2, 0, 10, 'Bar') fuellevelId = addChannel("FuelLevel", 1, 0, 0, 120, "L") temp1Id = addChannel ("HeadTemp" , 1, 0, 0, 170, 'C') temp2Id = addChannel ("EGT" , 10, 0, 0, 1000, 'C') ch1Id = addChannel ("BrakePos", 10, 0, 0, 100, "%") ch2Id = addChannel ("ClutchPos", 10, 0, 0, 100, "%") ch3Id = addChannel ("Brake", 1, 0, 0, 150, "Bar") ch4Id = addChannel ("Steering", 1, 0, -300, 300, "Deg") ch5Id = addChannel ("Lambda", 10, 2, -1, 1, "C") fuelPresId = addChannel ("FuelPress", 10, 2, 0, 10, "Bar") gearId = addChannel ("Gear", 10, 0, 0, 7, "#") --customize here for CAN channel mapping --format is: [CAN Id] = function(data) map_chan(<channel id>, data, <CAN offset>, <CAN length>, <multiplier>, <adder>) CAN_map = { [1056] = function(data) map_chan(rpmId, data, 0, 2, 1, 0) map_chan(gearId, data, 4, 2, 1, 0) map_chan_le(tempId, data, 6, 2, 0.1, 0) end, [1057] = function(data) map_chan(temp1Id, data, 0, 2, 0.1, 0) map_chan(temp2Id, data, 2, 2, 0.1, 0) map_chan(oilTempId, data, 4, 2, 0.1, 0) map_chan_le(oilPresId, data, 6, 2, 0.01, 0) end, [1058] = function(data) map_chan(ch3Id, data, 0, 2, 0.01, 0) map_chan(tpsId, data, 2, 2, 1, 0) map_chan(ch1Id, data, 4, 2, 1, 0) map_chan(ch2Id, data, 6, 2, 1, 0) end , [1059] = function(data) map_chan(ch4Id, data, 0, 2, 1, 0) map_chan(ch5Id, data, 2, 2, 0.01, 0) end, [1060] = function(data) map_chan(fuellevelId, data, 0, 2, 1, 0) map_chan(fuelPresId, data, 2, 2, 0.1, 0) end } function onTick() processCAN(CAN_chan) end --===========do not edit below=========== function processCAN(chan) repeat local id, e, data = rxCAN(chan) if id ~= nil then local map = CAN_map[id] if map ~= nil then map(data) end end until id == nil end --Map CAN channel, little endian format function map_chan_le(cid, data, offset, len, mult, add) offset = offset + 1 local value = 0 local shift = 1 while len > 0 do value = value + (data[offset] * shift) shift = shift * 256 offset = offset + 1 len = len - 1 end setChannel(cid, (value * mult) + add) end --Map CAN channel, big endian format function map_chan_be(cid, data, offset, len, mult, add) offset = offset + 1 local value = 0 while len > 0 do value = (value * 256) + data[offset] offset = offset + 1 len = len - 1 end setChannel(cid, (value * mult) + add) end map_chan = (be_mode == 1) and map_chan_be or map_chan_le initCAN(CAN_chan, CAN_baud) setTickRate(tickRate)
