PE3 CAN
The following script integrates the Performance Electronics PE3 ECU.
Reference Documentation=
Supported Channels
This integration supports the following channels:
- RPM
- TPS (Throttle Position)
- InjectorPw (Injector Pulse Width)
- Ignition (Ignition Advance)
- Baro (Barometer)
- MAP (Manifold Absolute Pressure)
- Lambda
- IAT (Air inlet temperature)
- EngineTemp
Connect the PE3 CAN High / CAN Low to the corresponding CAN High / CAN Low on the RaceCapture/Pro CAN 1 channel. See the [CAN_Bus_Integration|CAN integration guide]] for wiring details.
- Note: The PE3 ECU is already terminated with a 120 ohm resistor.
CAN integration script
Copy and paste this script into the scripting window of RaceCapture/Pro. Ensure any existing script is removed.
-- RaceCapture/Pro CAN mapping for Performance Electronics PE3 ECU
-- see rpmFilter() function
tickRate = 30
--the CAN baud rate
CAN_baud = 250000
CAN_chan = 0
--format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units])
rpmId = addChannel("RPM", 25, 0, 0, 10000)
tpsId = addChannel("TPS", 25, 0, 0, 100, "%")
fuelTimeId = addChannel("InjectorPw", 25, 2, 0, 30, "ms")
ignId = addChannel("Ignition", 25, 0.1, -20, 100, "deg")
baroId = addChannel("Baro", 1, 1, 0, 105, "kpa")
mapId = addChannel("MAP", 25, 1, 0, 255, "kpa")
lambdaId = addChannel("Lambda", 25, 3, -2, 2, "")
iatId = addChannel("IAT", 25, 1, 0, 255, "F")
tempId = addChannel("EngineTemp", 1, 0, 0, 255, "F")
function rpmFilter(value)
return value
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>,
-- <adder>, [filter])
CAN_map = {
[0x0CFFF048] = function(data) map_chan(rpmId, data, 0, 2, 1, 0, rpmFilter)
map_chan_s(tpsId, data, 2, 2, 0.1, 0)
map_chan_s(fuelTimeId, data, 4, 2, 0.01, 0)
map_chan_s(ignId, data, 6, 2, 0.1, 0)
end,
[0x0CFFF148] = function(data) map_chan_s(baroId, data, 0, 2, 0.01, 0)
map_chan_s(mapId, data, 2, 2, 0.01, 0)
map_chan_s(lambdaId, data, 4, 2, 0.001, 0)
end,
[0x0CFFF548] = function(data) map_chan_s(iatId, data, 2, 2, 0.1, 0)
map_chan_s(tempId, data, 4, 2, 0.1, 0)
processCAN(CAN_chan)
function processCAN(chan)
local msg = 0
repeat
local id, e, data = rxCAN(chan, 0)
local map = CAN_map[id]
if map ~= nil then
map(data)
msg = msg + 1
until id == nil or msg > 100
if offset + len > #data then return end
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
local cv = value * mult + add
setChannel(cid, cv)
function map_chan_s(cid, data, offset, len, mult, add, filter)
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
--adjust for sign
if value > 32767 then value = value - 65536 end
setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
