RaceCapture-Track
Revision as of 21:35, 20 August 2016 by Rdoherty (talk | contribs)
  1. Install software
    1. Download the latest RaceCapture app for your platform here: https://podium.live/software
  2. Configure track
    1. If RaceCapture does not have a track set, when you select the Dashboard view you will be prompted to set a track:
      Search for and select your track, then click/tap the checkbox to set the track.
    2. You can also change your track in the Tracks section in the Configuration screen:
  3. Setup OBDII (optional)
  4. Save Config
