RaceCapture-Track
Install software
Download the latest RaceCapture app for your platform here: https://podium.live/software
Also install the RaceCapture App on your phone or tablet. https://play.google.com/store/apps/details?id=com.autosportlabs.racecapture
Connect to RaceCapture
WiFi (Android/iOS)
By default, RaceCapture will setup a WiFi network named 'RaceCapture XXX' (XXX will be a random number). Connect to this WiFi network, then open the RaceCapture App.
USB (Windows/Mac/Linux)
Plug the USB cable into RaceCapture and your computer. Windows 10, Mac and Linux computers do not need any additional software to connect to RaceCapture.
Windows XP, 7, 8
- Plug RaceCapture in to the computer.
Configure track
If RaceCapture does not have a track set, when you select the Dashboard view you will be prompted to set a track:
Search for and select your track, then click/tap the checkbox to set the track.
You can also change your track in the Tracks section in the Configuration screen:
Setup OBDII (optional)
To setup OBDII channels, use the OBDII screen. Turn on OBDII channels and click the + button at the bottom to add a channel. Select the channel name and sample rate. Note: Due to the design of the OBD2 protocol, individual channels (PIDs) are requested sequentially, so individual channel rates decrease based on the number of channels enabled.
Save Config
Once configured, press the Save button on the bottom right to save your configuration. Now hit the track!
