Telemetry Quickstart
Prerequisites
Get a device Id
Integrated Telemetry
Purchasing a SIM Card
The RaceCapture telemetry unit requires a full-sized SIM card with a compatible data plan from a supported carrier.
Getting the IMEI
The carrier may ask for the IMEI. You can get the IMEI by connecting to RaceCapture/Pro and checking the cellular section of the System Status page:
- Note: If you have the 2.5G module, ensure you're powered up over 12v.
How much data will I need?
- Number of channels enabled
- Sample Rate of channels
Which SIM card to get?
AT&T (Recommended)
AT&T is now our recommended service as they have annouced affordable plans targeting tablets and other data-only devices.
When you arrive at the store:
- Ask for a full-sized SIM for a $15/month Gophone plan.
- If they ask for an IMEI number it's easiest to request they set a default number.
T-Mobile
- Ask for a full-sized SIM for a pre-paid $3/day plan
3rd party resellers (MVNOs)
- Straight talk wireless has some compelling plans starting at $15/month: http://www.straighttalkbyot.com/
Global/Other carriers
The RaceCapture/Pro uses a world-wide compatible GSM cellular module. Check with your carrier for support. You will also likely need to set a custom APN setting in the telemetry configuration. These APN settings are provided by the carrier.
Installing the SIM card
- Use a pen, stylus or similar press the yellow eject button next to the SIM card slot - the card slot will pop out slightly from the front panel. Manually withdraw it from the front panel.
- Insert the SIM card into the holder, noting the angled notch. Re-insert and press until the front edge is flush or just below the surface of the enclosure face.
IMPORTANT NOTES
- The SIM card tray inserts into the unit with the word "SIM" on the edge upside down, with the SIM card facing down.
- The card carrier should slide in smoothly, and require just a bit of force to lock in to place. Take care to not force the card in at an angle.
Attach Cellular Antenna
Connect the included antenna to the antenna port to the left of the SIM card slot. Tighten until snug.
- Do not over-tighten antenna connection
- Connect RaceCapture/Pro to your computer with USB and run the RaceCapture software.
- Note: If this is the first time connecting, be sure you've gone through the Quick Start Guide
- After the software detects and connects to RaceCapture/Pro, navigate to the configuration screen
Enable Telemetry and Device Id
- Select the Telemetry option on the left side
- In the Device ID field, enter the Device Id assigned to the device you created in your podium.live account.
- if your carrier is not listed, specify the APN settings provided by your wireless company.
- List of APNs worldwide
Write and Save Configuration
- Write your configuration back to the unit using the buttons in the lower left of the screen.
- Recommended: save your configuration to a file
Testing Telemetry
- Ensure the SIM card is installed in the RaceCapture/Pro unit per the earlier steps.
Powering up
3.5G module
If you are using the 3.5G module, you can power using USB on the bench, or via 12v.
2.5G module
Watching for telemetry
LED indicators
- When connected and transmitting, the top green telemetry LED will flash rapidly and steadily. This will also be indicated on the System Status page under the Telemetry section.
- See the Quick Reference guide
Once it is connected, you will see an Ad Hoc Event under your account on podium.live
- You can view the live data by clicking on the event
- You can also edit and rename this event
Setting up future events
- No 12v power (2.5G only) The internal telemetry module requires external 12v (via green terminal block or OBD-II cable)
- Note: 3.5G cellular telemetry can be used with USB only, due to the lower power requirements.
- Expired SIM card: Make sure your T-mobile or AT&T card has enough credit to enable data.
- Poor signal quality: Ensure coverage area.
- Loose antenna: Ensure the antenna is snugly cinched to the connector.
- Missing / Incorrect Device Id: Ensure RaceCapture/Pro is configured with a Device ID provided by podium.live
Debugging Cellular activity
Bluetooth Telemetry
RaceCapture/Pro settings
In the RaceCapture/Pro configuration software ensure following is set under the Wireless Configuration pane:
- Bluetooth is 'On'
- Cellular Module is 'Off'
When complete, write the updated configuration back to the RaceCapture/Pro device.
Install the RaceCapture Mobile App
Configure Bluetooth
- Plug the Bluetooth module into the wireless connectivity port on RaceCapture/Pro and apply power (12v or USB)
- Associate the Bluetooth module with your android device in the system settings.
- Default password is 1234
- In the RaceCapture App touch the Bluetooth icon and select the RaceCapturePro device you associated in the previous step.
- The RaceCapture app will negotiate a connection to RaceCapture/Pro.
- Once connected, the LED on the bluetooth module will remain steadily lit
- Tip 1 - If the the app does not connect, close the RaceCapture app completely (dismiss from the background apps) and re-start.
- Tip 2 - If you still cannot connect, enable / disable the bluetooth system in the device settings
Configure your Device Id
While connected to RaceCapture/Pro configure the device id you created on podium.live
Notes
- Ensure you write the config back to RaceCapture/Pro after setting the device id
- If cellular module is installed and enabled in RaceCapture/Pro, it will take priority over telemetry via app. To use in-app telemetry, disable the cellular module under the wireless configuration page.
Access the app preferences under the main menu. Switch the Application telemetry feature to 'On'
Verify Telemetry
- Dim Green Not active
- Red Connection Error
View Telemetry Stream
Once you've verified telemetry is streaming, you can visit the Events Page on your Podium account!
