RaceCapture-Track
Start it up
Plug it in
Download the app
- Google Play
- Amazon App Store
- When GPS receives a lock, RaceCapture will search for a known nearby track.
Setup Mode
- Note: Whenever you make a change on one of these pages, you will need to write your changes back to the RaceCapture device.
- Common baud rates for OBDII is 500K and 250K. The default is 500K, which applies to nearly every CAN OBDII vehicle.
- Note about unsupported channels: - If your ECU does not support a channel, the value will remain at 0. RaceCapture will time-out waiting for a response from the ECU, which will affect the performance of other channels. We recommend removing all unsupported channels to ensure optimal OBDII performance.
You can configure RaceCapture simultaneously for both Access Point and Client mode.
Telemetry
- Note: You will also need to enable telemetry in the top level application preferences. When telemetry is broadcasting, you will see a green cloud icon in the application toolbar.
Logs
Analysis Mode
Applying Decals
