ShiftX2
Revision as of 05:27, 8 June 2017 by Brentp (talk | contribs)
(Introduction about ShiftX2)
Scripts
Disco Lights Demo
Script
--implement me
Script
--implement me
Script
--implement me
Boost Gauge
Script
--implement me
Only Alerts
  • Left alert for oil pressure
Script
--implement me
ShiftX2 starter script
--implement me
ShiftX2 CAN bus API
CAN base ID is 744389
If the device supports hardware configurable ID offsets, such as via DIP switches or breakable jumpers, each incremental offset will add 1000 to the base ID.
Offset What Value
Reset Device
CAN ID: Base + 1
Offset What Value
(no data)
Offset What Value
(no data)
Offset What Value
0 Brightness 0 - 100 (0=automatic brightness)
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 11
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
  • Threshold value must be > 0 to be valid
  • Alerts are processed in descending order by alert ID and will be handled by the first threshold the current value exceeds.
CAN ID: Base + 12
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 13
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 14
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 15
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 16
Offset What Value
