How To Update Firmware
RaceCapture/Pro MK2 / MK3 / RaceCapture/Apex
Save your configuration
Download the firmware
  • Note Ensure you download the correct firmware for your device, or the firmware process will fail to complete.
Flash the firmware
Connect RaceCapture/Pro MK2 to your computer and connect to it with the app. Note: Flashing is only possible via the USB interface, so you must use the desktop version of the RaceCapture app.
Alternative method
Problems? Post to the forums with the issue you're seeing - we will help you promptly.
RaceCapture/Pro MK1
Alternatively:
Mac Users
