ShiftX2
(Introduction about ShiftX2)
Scripts
Disco Lights Demo
Script
Script
Script
Boost Gauge
Script
Only Alerts
- Left alert for oil pressure
Script
ShiftX2 starter script
ShiftX2 CAN bus API
If the device supports hardware configurable ID offsets, such as via DIP switches or breakable jumpers, each incremental offset will add 256 to the base ID.
| Offset | What | Value |
Reset Device
CAN ID: Base + 1
| (no data) | ||
| 0 | Brightness | 0 - 100 (0=automatic brightness) |
Set Discrete LED
CAN ID: Base + 10
| 2 | Red | 0 - 255 |
| 3 | Green | 0 - 255 |
| 4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
| 1 | Red | 0 - 255 |
| 2 | Green | 0 - 255 |
| 3 | Blue | 0 - 255 |
Set Alert Threshold
- Alerts are processed in descending order by Threshold ID, where:
- The threshold is selected where the threshold is > 0 and current value is >= threshold and < than the next threshold
- If the current value is less than the first threshold, then the alert indicator is disabled.
CAN ID: Base + 21
| 1 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
| 5 | Green | 0 - 255 |
| 6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
| 1 | Value (low byte) | |
| 2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Set Linear Graph Threshold
CAN ID: Base + 41
| 0 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
CAN ID: Base + 42
| 0 | Value (low byte) | |
| 1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
