ShiftX2
Revision as of 15:35, 21 June 2017 by Brentp (talk | contribs) (→‎Wiring)
In the kit you will receive:
  • ShiftX2 module
  • 4 wire pigtail
  • Acrylic enclosure
Assembling the enclosure
Mounting ShiftX2
Pinout
Color Assignment Notes
Red 5-12v Power Connect this to switched ignition power. 0.5A max consumption.
Black CAN High
Yellow CAN Low
Black Ground
To power ShiftX2, connect the Red wire to switched 12v, and the white wire to Ground.
  • You can use the same circuit for your RaceCapture system so they power up simultaneously.
  • Note You can choose either CAN1 or CAN2 to drive ShiftX2. The CAN bus can be defined in the script you use to control ShiftX2.
Scripts
Disco Lights Demo
Script
sxCan = 0
sxId=0
tickRate=30
sxBright=0
function rndc()
  return math.random(0,255)
function sxOnUpdate()
  for i=0,9,1 do
    r = rndc()
    g = rndc()
    b = rndc()
	sxSetLed(i,1,r,g,b,0)
function sxOnBut(d)
  println('button: ' ..d[1])
function sxOnInit()
  print('sx onInit')
--ShiftX2 library functions--
  sxTx(10,{i,l,r,g,b,f})
  sxTx(3,{bright})
function setAlert(id,r,g,b,f)
  sxTx(20,{id,r,g,b,f})
function updateAlert(id,v)
function updateLinearGraph(v)
  sxTx(42,{spl(v),sph(v)})
function sxInit()
  println('config shiftX2')
  setBaseConfig(sxBright)
function sxChkCan()
  id,ext,data=rxCAN(sxCan,0)
function sxProcess()
  sxChkCan()
function sxTx(offset, data)
  sleep(10)
  sxProcess()
sxInit()
Script
--implement me
Script
--implement me
Boost Gauge
Script
--implement me
Only Alerts
  • Left alert for oil pressure
Script
--implement me
ShiftX2 starter script
---ShiftX2 functions---
--Set an individual LED
--red: Red value (0-255)
--green: Green value (0-255)
--blue: Blue value(0-255)
--blue: Blue value (0-255)
--alertId: Alert Id to set
--currentValue: Updated value
--Configures the linear graph
--End reference
  sxTx(3,{bright})
function sxInit()
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
sxInit()
ShiftX2 CAN bus API
Offset What Value
Reset Device
CAN ID: Base + 1
Offset What Value
(no data)
Offset What Value
Offset What Value
0 Brightness 0 - 100; default = 0 (0=automatic brightness)
1 Automatic brightness scaling (Optional) 0-255; default=51
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 20
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
  • Threshold value must be > 0 to be valid
  • Alerts are processed in descending order by Threshold ID, where:
    • The threshold is selected where the threshold is > 0 and current value is >= threshold and < than the next threshold
    • If the current value is less than the first threshold, then the alert indicator is disabled.
CAN ID: Base + 21
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 22
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 41
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 42
Offset What Value
0 Value (low byte)
1 Value (high byte)
Notifications
Button State
CAN ID: Base + 60
Offset What Value
