RaceCapture on Raspberry Pi
Prerequisites
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
- Via raspi-config tool
- Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
Download the latest RaceCapture app package and place it in the /opt/ directory.
You can download it directly by getting the URL of the package by right-clicking the download link and copying it to your clipboard. Then, use it in the command below:
Extract the package
sudo tar -xzvf <downloaded file>
Launch the app
