RaceCapture on Raspberry Pi
Prerequisites
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
- Via raspi-config tool
- Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
Extract the package
Launch the app
Launching with Watchdog
You can launch the RaceCapture app with an automatic watchdog that re-launches the app in case a crash occurs.
killall -9 run_racecapture.sh
