RaceCapture on Raspberry Pi
Prerequisites
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
- Via raspi-config tool
- Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture.sh
Automatic start upon power up
To get the full dedicated dashboard effect, you can have the RaceCapture App run automatically upon power up.
sudo nano /etc/rc.local
and add the following line to the end of the file:
/opt/racecapture/run_racecapture/sh -w 1 &
