RaceCapture on Raspberry Pi
Benefits
- Automatically runs upon power up - no app to launch
- Hard-wired data connection to RaceCapture - no wireless connection to configure
- Runs on the bare metal - the RaceCapture app runs without Android or iOS; no other apps competing for resources, or compromising system stability.
- Overheating resistance - Your typical mobile device requires extra care to prevent damage to it's internal battery and will shut down if overheated. With proper heat-sinking, the Raspberry Pi can bypass these issues.
Experimental
These instructions are for those adventurous race car hackers who know their away around a command line, comfortable working with hardware and want to dig in. The results are pretty great!
We've created a downloadable install package for the RaceCapture app that is as close to self-running as possible on a bone stock Raspbian Jesse image - see the instructions below to start.
Upcoming, we will create a dedicated Raspberry Pi image that you can burn to an SD card and simply boot.
Hardware Selection
Raspberry Pi
Display
Other displays can work as well, and additional work may be needed to support the screen's touch controller.
If unsure, just pick the Official Raspberry Pi display
Installing Rasbian OS
Installing dependencies
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
- Via raspi-config tool
- Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture.sh
Automatic start upon power up
sudo nano /etc/rc.local
