RaceCapture on Raspberry Pi
Revision as of 22:44, 12 July 2017 by Brentp (talk | contribs) (Benefits)
Benefits
  • Automatically runs upon power up - no app to launch.
  • Runs on the bare metal - the RaceCapture app runs without Android or iOS; no other apps competing for resources, or compromising system stability.
  • Overheating resistance - Your typical mobile device requires extra care to prevent damage to it's internal battery, and will shut down if overheated. With proper heat-sinking, the Raspberry Pi should handle the heat.
Experimental!
While the results are pretty great, these instructions are currently for those adventurous race car hackers who know their away around a command line, comfortable working with hardware and want to dig in.
Hardware Selection
Raspberry Pi
Display
Power Supply
To power everything, you'll need a high quality 2 amp charger - preferably one designed to be hard wired into your car for maximum reliability.
Heat sinking
Installing Rasbian OS
Installing dependencies
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
  • Via raspi-config tool
  • Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
cd /opt
sudo wget <package URL>
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture.sh
Automatic start upon power up
sudo nano /etc/rc.local
exit 0
Connect your RaceCapture/Pro or RaceCapture/Track to the Raspberry Pi using the USB cable. Once the app is running and RaceCapture is connected, you'll it connect automatically.
Use the app just as you would on Android or iOS.
