RaceCapture on Raspberry Pi
Revision as of 01:29, 8 March 2019 by Brentp (talk | contribs) (→Benefits)
Benefits
Compatibility
Experimental!
While the results are pretty great, these instructions are currently for those adventurous race car hackers who know their away around a command line, comfortable working with hardware and want to dig in. Think it's cool, but too much to tackle? Rope in your nearest computer/electronics geek - you need one on your race team, anyway. :)
Hardware Selection
Raspberry Pi
Display
Power Supply
To power everything, you'll need a high quality 5v power supply with 2 amps minimum capacity; 3 amps is highly recommended. You'll preferably want one designed to be hard wired into your car for maximum reliability.
Heat sinking
Installing Rasbian OS
Installing dependencies
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
  • Via raspi-config tool
  • Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
cd /opt
sudo wget <package URL>
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture.sh
Automatic start upon power up
sudo nano /etc/rc.local
exit 0
Powering up
Connection and usage
Extra Features
Hardwire buttons
