AnalogX
AnalogX CAN bus API
Adjusting Base ID
The base address is determined by the state of the ADR1 and ADR2 jumpers. By default, the jumpers are bridged; cutting the jumper ADR1 will add 256 to the base ID, and cutting jumper ADR2 will add 512 to the base ID.
| ADR2 | ADR1 | Address |
| Default | Default | 0xE4600 (935424) |
| Default | Cut | 0xE4700 (935680) |
| Cut | Default | 0xE4800 (935936) |
| Cut | Cut | 0xE4900 (936192) |
| Offset | What | Value |
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
Configuration Group 1
Send this message to AnalogX to configure runtime settings. These settings are volatile.
Address
| 1 | Reserved | |
| 2 | Reserved | |
| 3 | Reserved | |
| 4 | Reserved | |
| 5 | Reserved | |
| 6 | Reserved | |
| 7 | Reserved |
Sample Broadcast
Scaling and Data format
- Scaling: 0-5000mV
- Data format: Little Endian
Address
- CAN ID: Base + 20
| 0 | Channel 1, low byte | |
| 2 | Channel 2, low byte | |
| 4 | Channel 3, low byte | |
| 6 | Channel 4, low byte | |
| 7 | Channel 4, high byte |
