AIM SmartyCam CAN
Connecting to the AIM system
| AIM cable connection mapping | ||||||
| Connection | AIM Pin (Binder 702) | RaceCapture/Pro Pin (EIA-T568B Ethernet cable) | ||||
| CAN High | 1 (White) | 2 (Orange) | ||||
| CAN Low | 4 (Blue) | 3 (Green / White) | ||||
| Ground | 2 (Brown) | 1 (Orange / White) | ||||
| VBExt | 3 | N/C (Do not connect) | ||||
Note
- RaceCapture/Pro provides a 12v input pin (Pin 8) on the RJ45 connector, which has a common connection to the 12v input of the RaceCapture/Pro terminal block.
- This pin is rated at 1A max. We do not recommend using this pin to supply power to the AIM Smarty CAM.
Available Channels
| BMW E46 (including M3) | ||||||
| AIM Channel Name | RaceCapture channel name | |||||
| RPM | RPM | |||||
| Gear | Gear | |||||
| WaterTemp | EngineTemp | |||||
| Oil Press | OilPress | |||||
| Oil Temp | OilTemp | |||||
| Throttle Position | TPS | |||||
| Head Temp | HeadTemp | |||||
| Exhaust Temp | EGT | |||||
| Brake Pos (channel 1) | BrakePos | |||||
| Clutch Pos (channel 2) | Clutch | |||||
| Brake Press (channel 3) | Brake | |||||
| Steer Position (channel 4) | Steering | |||||
| Lambda (channel 5) | Lambda | |||||
| FuelLevel | FuelLevel | |||||
Integration Cable
Build your own
Get a pre-made cable
AIM Integration configuration
Direct CAN channel Mapping (in verification process)
Download this starter configuration to instantly import 17 pre-configured channels mapped to your AIM Smarty Cam data.
Instructions:
- Save any existing channel configuration, such as your analog sensors, as this starter configuration will overwrite your current configuration.
- Download the starter configuration file, and unzip, extracting the .rcp file.
- Connect the RaceCapture app to your RaceCapture system
- Go to Setup, and press Open to open the unzipped configuration file.
- Press Write to write the configuration to your RaceCapture system.
- Switch to the Dashboard view to monitor and verify the AIM SmartyCAM channels.
Lua script mapping (old approach)
The original integration uses the Lua scripting technology to map AIM data channels. We recommend using the Direct CAN channel mapping approach above.
- Note - ensure any existing script is removed before copying in the AIM integration script.
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 0
CAN_map = {
processCAN(CAN_chan)
function processCAN(chan)
repeat
local map = CAN_map[id]
if map ~= nil then
map(data)
until id == nil
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
initCAN(CAN_chan, CAN_baud)
