BMW E30 Guide
Revision as of 04:13, 11 November 2017 by Sbarton (talk | contribs) (→Fuel Level)
BMW E30 (1982 to 1993)
Use the Black wire in the C101 plug feeding from the ECU to the instrument cluster.
RaceCapture/Pro timer configuration
  • Timer Mode: RPM
  • Timer Speed: Medium
  • Pulse Per Revolution: 3
Engine Temperature
In research
Fuel Level
Map values in RCP:
  • 4.3v = 0 (empty)
  • 2.28v = 50 (half)
  • 0.55v = 100 (full)
Oil Pressure
