AIM SmartyCam CAN
Connecting to the AIM system
AIM cable connection mapping
Connection AIM Pin (Binder 702) RaceCapture/Pro Pin (EIA-T568B Ethernet cable)
CAN High 1 (White) 2 (Orange)
VBExt 3 N/C (Do not connect)
Note
  • RaceCapture/Pro provides a 12v input pin (Pin 8) on the RJ45 connector, which has a common connection to the 12v input of the RaceCapture/Pro terminal block.
  • This pin is rated at 1A max. We do not recommend using this pin to supply power to the AIM Smarty CAM.
Available Channels
BMW E46 (including M3)
RPM RPM
Gear Gear
WaterTemp EngineTemp
Oil Press OilPress
Oil Temp OilTemp
Throttle Position TPS
Head Temp HeadTemp
Exhaust Temp EGT
Clutch Pos (channel 2) Clutch
Brake Press (channel 3) Brake
Lambda (channel 5) Lambda
FuelLevel FuelLevel
Integration Cable
Build your own
Get a pre-made cable
AIM Integration configuration
Direct CAN channel Mapping
Instructions:
  • Save any existing channel configuration, such as your analog sensors, as this starter configuration will overwrite your current configuration.
  • Unzip the downloaded AIM SmartyCAM configuration and extract the .rcp file.
  • Connect the RaceCapture app to your RaceCapture system
  • Go to Setup, and press Open to open the unzipped configuration file.
  • Press Write to write the configuration to your RaceCapture system.
  • Switch to the Dashboard view to monitor and verify the AIM SmartyCAM channels.
Important Note
  • If you are converting from the Lua script integration to direct CAN mapping, be sure to completely remove your Lua script mapping by erasing the Lua scripting window and writing the configuration back to RaceCapture.
  • Full guide on CAN Mapping here.
Lua script mapping (old approach)
The original integration uses the Lua scripting technology to map AIM data channels. We recommend using the Direct CAN channel mapping approach mentioned above.
  • Note - ensure any existing script is removed before copying in the AIM integration script.
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 0
CAN_map = {
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
initCAN(CAN_chan, CAN_baud)
