PodiumConnect
Getting Started
Installing the app
Install the beta 1.12.0 app from http://podium.live/software (Windows or OSX)
Android: Follow this link to get the Beta 1.12.0 app: https://play.google.com/apps/testing/com.autosportlabs.racecapture
First time setup wizard
Recommend setting up with windows/OSX to start.
Plug RaceCapture into the USB port on your computer and launch the app.
The app will present you with a startup wizard. Follow the steps.
When presented with the presets, Select AiM as your preset.
Select your favorite Tracks
Select the tracks you will typically race at so PodiumConnect can detect the track location and calculate lap times.
Note: Only select the one track configuration per venue.
Create an account on Podium
Create an account on Podium http://podium.live - then follow the steps to create a Device. Note the Device ID provided, you will need to enter it into the wizard.
Select your cell provider
Select the cellular provider you will use.
Verifying connectivity with data system
- Connect the integration cable between your data system and PodiumConnect.
- Navigate to the dashboard view in the app, and press the left arrow in the lower left of the screen, until you see a page with many channels listed.
- Verify you are seeing data in the GPS and sensor channels flowing from the data system.
Testing Telemetry
Install your SIM card
Insert your SIM card by popping the drawer
- Slide the SIM card tray back into the drawer, ensuring you engage the drawer slot carefully. Press until the drawer seats.
Testing Telemetry
- Refresh this page when telemetry is broadcasting; you will see an "Ad Hoc event" listed.
