ShiftX3
In the kit you will receive:
- ShiftX3 module
- 2 M2x5mm screws for enclosure assembly
- 2 #6 screws for surface mounting
(3D printed enclosure not included)
Dimensions
- ShiftX3 bare board: 114 x 27mm (4.48 x 1.06 inches)
ShiftX3 is designed to be surface mounted with the companion enclosure, or it can be embedded into your dashboard in a custom installation.
Printing the enclosure
The enclosure can be 3D printed by downloading the printer files.
File:Shiftx3 enclosure rev A.zip
The enclosure consists of the following parts:
- shiftx3.stl : Main housing for ShiftX3 - Qty 1 needed
- shiftx3_back_3dprint: Back cover for housing - Qty 1 needed
- shiftx3_light_pipe.stl: Light pipe for LEDs - Qty 9 needed
- shiftx3_light_pipe_photosensor.stl: Light pipe for photosensor - Qty 1 needed
Color and material are not critical for the enclosure; however we recommend PETG or ABS.
Printing light pipes
Print the 9 LED light pipes and 1 photosensor light pipe in clear filament. PETG is recommended for optical clarity.
Enclosure clean up
Ensure extra filament is completely removed from the inside of the enclosure and is completely clean, so the ShiftX3 circuit board can fit flush and level inside the enclosure.
3D printing notes
- Print extra light pipes and print with a brim to purge heat-scorched / darkened filament from the extruder.
- Avoid printing just one light pipe at a time - printing just one will cause the part to sag and deform due to concentrated heat in the small part. We recommend you print at least 4 at a time to ensure heat is distributed across the parts and retain dimensional accuracy.
Assembling the enclosure
Install light pipes
Press the LED light pipes into the enclosure from the back side, ensuring they are flush with the front.
- Note -The LED light pipes have a small lip that locks into the back surface.
Press the photo sensor light pipe into the front of the enclosure. There should be a tight interference fit; if there is not, use a tiny drop of super glue from the back side of the enclosure to secure it.
Install ShiftX3
Install ShiftX3 into the back of the enclosure, guiding the switches into their respective hole.
- Note - Take care to not torque the switch handles sideways to prevent damage.
Gently press the back of ShiftX3 board so that it is fully seated into the enclosure. There should be a 0.5mm lip around the back of the enclosure where the back plate will lock into place.
ShiftX3 in white ABS
ShiftX3 in black ABS
Install the back panel of ShiftX3 so the shallow lip of the back panel sits within the recess of the ShiftX3 enclosure.
When pressed together, there should be no gap between the enclosure and the back plate. If there is, check the inside of the enclosure to clean up any additional 3D printed filament.
Secure the back plate using the two M2x5mm screws. Do not over-torque.
Connection and Installation
Mounting ShiftX3
Integration with RaceCapture / PodiumConnect
Suggested parts:
- RJ45 Splitter "Hub" shaped
Patching the RJ45 cable to ShiftX3
You will need to splice ShiftX3 to the conductors of the patch cable. Start by snipping the RJ45 connector off the end of a patch cable, and then expose the individual wires.
ShiftX3 connection | RaceCapture Connection | CAT5 EIA-T568B RJ45 cable |
Red | +12v | Brown |
White | Ground | Orange/White |
No Connection | CAN 1 High | Orange |
No Connection | CAN 1 Low | Green/White |
Black | CAN 2 High | Blue |
Yellow | CAN 2 Low | Blue/White |
CAN termination is enabled by default. To disable termination, cut the CAN Term jumper on the bottom of ShiftX3.
Scripts
Disco Lights Demo
Script
sxCan = 1 sxId=0 tickRate=30 sxBright=0 disp = 0 function rndc() return math.random(0,255) end function sxOnUpdate() for i=0,9,1 do r = rndc() g = rndc() b = rndc() sxSetLed(i,1,r,g,b,0) end --sxSetDisplay(math.random(0,9)) end function sxOnBut(b, id) println('button: ' ..b ..' ' ..id) if b == 0 then return end if id == 1 then disp = disp + 1 end if id == 0 then disp = disp - 1 end sxSetDisplay(disp) end function sxOnInit() print('sx onInit') end --ShiftX3 library functions-- function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function sxSetBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxSetDisplay(value) sxTx(50, {0, 48+value}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) sxTx(42,{spl(v),sph(v)}) end function sxInit() println('config ShiftX3') sxSetBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1], data[2]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) println('Shiftx3 base id ' ..sxCanId) setTickRate(tickRate) sxInit()
Sequential shift light
Script
- Default is reading RPM via OBDII. You can change to direct RPM input in the script.
-- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2 sxCan = 1 -- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut) sxId=0 --how often ShiftX3 is updated tickRate=30 --Brightness, 0-100. 0=automatic brightness sxBright=0 function sxOnUpdate() --add your code to update ShiftX3 alerts or linear graph during run time. --Runs continuously based on tickRate. --uncomment the below for OBDII RPM PID sxUpdateLinearGraph(readOBD2(12)) --uncomment the below for Direct RPM on input 0 --sxUpdateLinearGraph(getTimerRpm(0)) end function sxOnInit() --config shift light sxCfgLinearGraph(0,0,0,7000) --left to right graph, linear style, 0 - 7000 RPM range sxSetLinearThresh(0,0,3000,0,255,0,0) --green at 3000 RPM sxSetLinearThresh(1,0,5000,255,255,0,0) --yellow at 5000 RPM sxSetLinearThresh(2,0,6000,255,0,0,10) --red+flash at 6500 RPM end function sxOnBut(b) --called if the button state changes println('button: ' ..b) end ---ShiftX3 functions function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function setBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) if v ~= nil then sxTx(42,{spl(v),sph(v)}) end end function sxInit() println('config ShiftX3') setBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) println('Shiftx3 base id ' ..sxCanId) setTickRate(tickRate) sxInit()
Assumptions:
- Engine Temperature on the 1st alert LED, connected to first analog channel
- Oil Pressure on the 2nd alert LED, connected to second analog channel
Script
-- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2 sxCan = 1 -- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut) sxId=0 --how often ShiftX3 is updated tickRate=30 --Brightness, 0-100. 0=automatic brightness sxBright=0 function sxOnUpdate() --add your code to update ShiftX3 alerts or linear graph during run time. --Runs continuously based on tickRate. --uncomment the below for OBDII RPM PID sxUpdateLinearGraph(readOBD2(12)) --uncomment the below for Direct RPM on input 0 --sxUpdateLinearGraph(getTimerRpm(0)) --update engine temp alert sxUpdateAlert(0, getAnalog(0)) --update oil pressure alert sxUpdateAlert(1, getAnalog(1)) end function sxOnInit() --config shift light sxCfgLinearGraph(0,0,0,7000) --left to right graph, linear style, 0 - 7000 RPM range sxSetLinearThresh(0,0,3000,0,255,0,0) --green at 3000 RPM sxSetLinearThresh(1,0,5000,255,255,0,0) --yellow at 5000 RPM sxSetLinearThresh(2,0,6000,255,0,0,10) --red+flash at 6500 RPM --configure first alert (right LED) as engine temperature (F) sxSetAlertThresh(0,0,205,255,255,0,0) --yellow warning at 205F sxSetAlertThresh(0,1,225,255,0,0,10) -- red flash at 225F --configure second alert (left LED) as oil pressure (PSI) sxSetAlertThresh(1,0,0,255,0,0,10) --red flash below 15 psi sxSetAlertThresh(1,1,15,255,255,0,5) --yellow flash 15-20 PSI sxSetAlertThresh(1,2,20,0,0,0,0) --above 20, no alert end function sxOnBut(b) --called if the button state changes println('button: ' ..b) end ---ShiftX3 functions function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function setBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) if v ~= nil then sxTx(42,{spl(v),sph(v)}) end end function sxInit() println('config shiftX3') setBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) println('shiftX3 base id ' ..sxCanId) setTickRate(tickRate) sxInit()
Script
-- Predictive time visualizer -- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2 sxCan = 1 -- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut) sxId=1 --how often ShiftX3 is updated tickRate=30 --Brightness, 0-100. 0=automatic brightness sxBright=0 --save best lap time bestTime = 0 function sxOnUpdate() local predTime = getPredTime() local timeDiff = (bestTime - predTime) * 60 -- rail values timeDiff = math.max(timeDiff, -10) timeDiff = math.min(timeDiff, 10) --scale values from +/- 10 sec to a 0-200 scale timeDiff = (timeDiff + 10) * 10 sxUpdateLinearGraph(timeDiff) --update best lap time if an updated lap time is available local lastLapTime = getLapTime() if lastLapTime < bestTime or bestTime == 0 then bestTime = lastLapTime end end function sxOnInit() --config shift light sxCfgLinearGraph(1,0,0,200) --center-out graph, linear style, +/- 10.0 seconds in 0.1 sec resolution sxSetLinearThresh(0,0,0,255,0,0,0) --red if you're falling behind best lap sxSetLinearThresh(1,0,80,0,0,255,0) --blue if you're close to best lap sxSetLinearThresh(2,0,110,0,255,0,0) --green if you're beating best lap end function sxOnBut(b) --if button is pressed, reset the best lap time bestTime = 0 end ---ShiftX3 functions function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function setBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) if v ~= nil then sxTx(42,{spl(v),sph(v)}) end end function sxInit() println('config ShiftX3') setBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) setTickRate(tickRate) sxInit()
Boost Gauge
Assumptions
- MAP sensor channel is on the first Analog channel, and reads in KPa - typically 0-255. You can also connect this to the MAP reading on OBDII (PID 11)
Script
-- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2 sxCan = 1 -- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut) sxId=1 --how often ShiftX3 is updated tickRate=30 --Brightness, 0-100. 0=automatic brightness sxBright=0 function sxOnUpdate() local map = getAnalog(0) --MAP sensor in KPa --convert to PSI boost local boost = math.max(map - 100, 0) * .145038 sxUpdateLinearGraph(boost) println(map ..' ' ..boost) end function sxOnInit() --config shift light sxCfgLinearGraph(0,0,0, 20) --left to right graph, linear style, 0 - 20 PSI boost sxSetLinearThresh(0,0,0,0,255,0,0) --green starting at no boost sxSetLinearThresh(1,0,10,255,255,0,0) --yellow starting at 10 PSI boost sxSetLinearThresh(2,0,15,255,0,0,10) --red+flash at 15 PSI boost end function sxOnBut(b) --called if the button state changes println('button: ' ..b) end ---ShiftX3 functions function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function setBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) if v ~= nil then sxTx(42,{spl(v),sph(v)}) end end function sxInit() println('config ShiftX3') setBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) println('ShiftX3 base id ' ..sxCanId) setTickRate(tickRate) sxInit()
Only Alerts
- Left alert for oil pressure
Script
ShiftX3 starter script
-- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2 sxCan = 0 -- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut) sxId=0 --how often ShiftX3 is updated tickRate=30 --Brightness, 0-100. 0=automatic brightness sxBright=0 function sxOnUpdate() --add your code to update ShiftX3 alerts or linear graph during run time. --Runs continuously based on tickRate. end function sxOnInit() --add your code for configuring ShiftX3. Runs once during startup end function sxOnBut(b) --called if the button state changes println('button: ' ..b) end ---ShiftX3 functions --=============== --Reference. Delete me to save space --=============== --function sxSetLed(index,length,red,green,blue,flash) --Set an individual LED --index: LED index, starting at 0 --length: number of LEDs to set at once --red: Red value (0-255) --green: Green value (0-255) --blue: Blue value(0-255) --flashHz: Flash rate, in Hz; 0=no flash --sxSetLinearThresh(thresholdId,segmentLength,thresholdValue,red,green,blue,flashHz) --Setup a threshold for the linear graph --thresholdId: Threshold ID to set. from 0-4. define in ascending order. --segmentLength: Length of the segment when in stepped graph mode. ignored for smooth mode. --thresholdValue: Value for this threshold. --red: Red value (0-255) --green: Green value (0-255) --blue: Blue value (0-255) --flashHz: Flash rate, in Hz; 0=no flash --sxSetAlertThresh(alertId,thresholdId,thresholdValue,red,green,blue,flashHz) --Setup a threshold for an alert indicator --alertId: Id of the alert to configure --thresholdId: Threshold ID to set. from 0-4. define in ascending order. --thresholdValue: Value for this threshold. --red: Red value (0-255) --green: Green value (0-255) --blue: Blue value (0-255) --flashHz: Flash rate, in Hz; 0=no flash --sxSetAlert(alertId,red,green,blue,flashHz) --Directly sets an alert indicator --alertId: Alert Id to set --red: Red value (0-255) --green: Green value (0-255) --blue: Blue value (0-255) --flashHz: Flash rate, in Hz; 0=no flash --sxUpdateAlert(alertId,currentValue) --Updates Current alert value, using the previously configured thresholds --alertId: Alert Id to set --currentValue: Updated value --sxCfgLinearGraph(renderStyle,linearStyle,lowRange,highRange) --Configures the linear graph --renderStyle: 0=left->right, 1=center,2=right->left --linearStyle: 0=smooth/interpolated, 1=stepped --lowRange: low range of the graph --highRange: high range of the graph (ignored if stepped linear style) --sxUpdateLinearGraph(currentValue) --Updates the linear graph value, using the previously configured thresholds --currentValue: Updated value --=============== --End reference --=============== function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function setBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) sxTx(42,{spl(v),sph(v)}) end function sxInit() println('config ShiftX3') setBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) println('ShiftX3 base id ' ..sxCanId) setTickRate(tickRate) sxInit()
ShiftX3 CAN bus API
Offset | What | Value |
1 | Automatic brightness scaling (Optional) | 0-255; default=51. adjust this value to adjust the relative gain of the built-in light sensor when in automatic brightness mode. |
Set Discrete LED
CAN ID: Base + 10
2 | Red | 0 - 255 |
3 | Green | 0 - 255 |
4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
1 | Red | 0 - 255 |
2 | Green | 0 - 255 |
3 | Blue | 0 - 255 |
Set Alert Threshold
CAN ID: Base + 21
1 | Threshold ID | 0 - 4 |
2 | Threshold (low byte) | |
3 | Threshold (high byte) | |
4 | Red | 0 - 255 |
5 | Green | 0 - 255 |
6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
1 | Value (low byte) | |
2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
2 | Low Range (low byte) | |
3 | Low Range (high byte) | |
Set Linear Graph Threshold
CAN ID: Base + 41
0 | Threshold ID | 0 - 4 |
4 | Red | 0 - 255 |
CAN ID: Base + 42
0 | Value (low byte) | |
1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
