RCP stimulator
RS232 serial output
Baud Rate
Baud rate is 115200, 8N1
Format
  • Timestamp in milliseconds
  • Channel 1 value (0-10000)
  • Channel 2 value (0-10000)
  • Channel 3 value (0-10000)
  • Channel 4 value (0-10000)
initSer(6, 115200, 8, 0, 1)
 value = readSer(6, 100)
  print('read value: ' ..value)
38817 ,0,0,0,0
39017 ,0,0,0,0
39217 ,0,0,0,0
39417 ,0,0,0,0
39617 ,0,0,0,0
39817 ,0,0,0,0
40017 ,0,0,0,0
40217 ,0,0,0,0
40417 ,0,0,0,0
40617 ,0,0,0,0
40817 ,0,0,0,0
41017 ,302,0,0,0
41217 ,1110,0,0,0
41417 ,1940,0,0,0
41617 ,1943,0,0,0
41817 ,1943,0,0,0
42017 ,1940,0,0,0
42217 ,1942,717,0,0
42417 ,1935,1321,0,0
42617 ,1935,1363,0,0
42817 ,1938,1363,0,0
43017 ,1940,1363,0,0
43217 ,1937,1362,795,0
43417 ,1938,1360,1478,0
43617 ,1939,1362,1473,0
43817 ,1938,1360,1477,0
44017 ,1937,1358,1477,0
44217 ,1938,1360,1476,513
44417 ,1934,1359,1477,1482
44617 ,1938,1360,1474,1489
