RCP stimulator
RS232 serial output
Baud Rate
Baud rate is 115200, 8N1
Format
- Timestamp in milliseconds
- Channel 1 value (0-10000)
- Channel 2 value (0-10000)
- Channel 3 value (0-10000)
- Channel 4 value (0-10000)
- Value echoed back from received data
initSer(6, 115200, 8, 0, 1)
--write something to be echoed back on last line
writeSer(6, 'echo')
value = readSer(6, 1000)
print('read value: ' ..value)
38817 ,0,0,0,0 39017 ,0,0,0,0 39217 ,0,0,0,0 39417 ,0,0,0,0 39617 ,0,0,0,0 39817 ,0,0,0,0 40017 ,0,0,0,0 40217 ,0,0,0,0 40417 ,0,0,0,0 40617 ,0,0,0,0 40817 ,0,0,0,0 41017 ,302,0,0,0 41217 ,1110,0,0,0 41417 ,1940,0,0,0 41617 ,1943,0,0,0 41817 ,1943,0,0,0 42017 ,1940,0,0,0 42217 ,1942,717,0,0 42417 ,1935,1321,0,0 42617 ,1935,1363,0,0 42817 ,1938,1363,0,0 43017 ,1940,1363,0,0 43217 ,1937,1362,795,0 43417 ,1938,1360,1478,0 43617 ,1939,1362,1473,0 43817 ,1938,1360,1477,0 44017 ,1937,1358,1477,0 44217 ,1938,1360,1476,513 44417 ,1934,1359,1477,1482 44617 ,1938,1360,1474,1489
