ShiftX3
In the kit you will receive:
- ShiftX3
- 2 #6 screws for surface mounting
Dimensions
Connection and Installation
Mounting ShiftX3
- RJ45 Splitter
- RJ45 network cable
OBDII Cable integration
OBDII installation is plug and play:
Non OBDII installation
RJ45 power cable for ShiftX3
| ShiftX3 connection | RaceCapture Connection | CAT5 EIA-T568B RJ45 cable |
| Red | +12v | Brown |
| Black | CAN 2 High | Blue |
CAN termination is enabled by default. To disable termination, cut the CAN Term jumper on the bottom of ShiftX3.
Scripts
Disco Lights Demo
Script
setTickRate(30)
-- Set configuration. Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar)
sxSetConfig(1, 0xE4600, bright,sxAutoBrightScaling,orientInverted)
function rndc()
return math.random(0,255)
for i=0,9,1 do
r = rndc()
g = rndc()
b = rndc()
sxSetLed(i,1,r,g,b,0)
Sequential shift light
Script
setTickRate(30)
-- Set ShiftX3 configuration
sxSetConfig(1, 0xE4600, 0, 61, 0)
--config shift light
Assumptions:
- Engine Temperature on the 1st alert LED, connected to first analog channel
- Oil Pressure on the 2nd alert LED, connected to second analog channel
Script
setTickRate(30)
--update RPM
--update engine temp alert
--update oil pressure alert
Script
-- Predictive time visualizer
-- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2
sxCan = 1
-- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut)
sxId=1
--how often ShiftX3 is updated
tickRate=30
sxBright=0
--save best lap time
bestTime = 0
function sxOnUpdate()
-- rail values
sxUpdateLinearGraph(timeDiff)
function sxOnInit()
function sxOnBut(b)
bestTime = 0
---ShiftX3 functions
sxTx(10,{i,l,r,g,b,f})
sxTx(3,{bright})
sxTx(20,{id,r,g,b,f})
function sxUpdateAlert(id,v)
function sxInit()
println('config ShiftX3')
setBaseConfig(sxBright)
function sxChkCan()
id,ext,data=rxCAN(sxCan,0)
function sxProcess()
sxChkCan()
function sxTx(offset, data)
sleep(10)
sxProcess()
sxInit()
Boost Gauge
Assumptions
- MAP sensor channel is on the first Analog channel, and reads in KPa - typically 0-255. You can also connect this to the MAP reading on OBDII (PID 11)
Script
sxCan = 1
sxId=1
tickRate=30
sxBright=0
--convert to PSI boost
sxUpdateLinearGraph(boost)
println(map ..' ' ..boost)
function sxOnInit()
function sxOnBut(b)
println('button: ' ..b)
sxTx(3,{bright})
function sxInit()
function sxChkCan()
sxChkCan()
sleep(10)
sxProcess()
println('ShiftX3 base id ' ..sxCanId)
sxInit()
Only Alerts
- Left alert for oil pressure
Script
ShiftX3 CAN bus API
| Offset | What | Value |
| 1 | Automatic brightness scaling (Optional) | 0-255; default=51. adjust this value to adjust the relative gain of the built-in light sensor when in automatic brightness mode. |
Set Display
CAN ID: Base + 50
Set Discrete LED
CAN ID: Base + 10
| 2 | Red | 0 - 255 |
| 3 | Green | 0 - 255 |
| 4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
| 1 | Red | 0 - 255 |
| 2 | Green | 0 - 255 |
| 3 | Blue | 0 - 255 |
Set Alert Threshold
CAN ID: Base + 21
| 1 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
| 5 | Green | 0 - 255 |
| 6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
| 1 | Value (low byte) | |
| 2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Set Linear Graph Threshold
CAN ID: Base + 41
| 0 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
CAN ID: Base + 42
| 0 | Value (low byte) | |
| 1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
