ShiftX3
Revision as of 00:32, 8 February 2019 by Brentp (talk | contribs) (→‎Script)
  • ShiftX3
  • ShiftX3
  • RJ45 CAN hub
  • Low profile RJ45 Cable
Dimensions
Compatibility
ShiftX3 is compatible with:
  • RaceCapture/Track MK2
  • RaceCapture/Pro MK2 and MK3
  • RaceCapture/Apex
  • PodiumConnect
Connection and Installation
Mounting ShiftX3
  • RJ45 Splitter
  • RJ45 network cable
  • Plug the OBDII cable into the CAN hub
Non OBDII installation
  • Note:
RJ45 power cable for ShiftX3
Red +12v Brown
White Ground Orange/White
Black CAN 2 High Blue
Yellow CAN 2 Low Blue/White
ShiftX3 Features
Disco Lights Demo
Script
-- Set configuration. Parameters:
-- orientation (0=normal, 1=display above LED bar) (required)
-- brightness (0-100%, 0 = auto brightness)
-- can bus (0=CAN1, 1=CAN2)
-- auto brightness scaling)
sxSetConfig(1)
function rndc()
  return math.random(0,255)
  for i=0,9,1 do
    r = rndc()
    g = rndc()
    b = rndc()
    sxSetLed(i,1,r,g,b,0)
  sxSetDisplay(0, math.random(48,57))
Sequential shift light
Script
  • Default is reading Gear from the channel named "Gear"
setTickRate(30)
-- Set ShiftX3 configuration parameters:
sxSetConfig(1)
--config shift light
Assumptions:
Script
setTickRate(30)
sxSetConfig(1, 0xE3600, 0, 61, 0)
  --update RPM
  --update engine temp alert
  --update oil pressure alert
Script
-- Predictive time visualizer
--save best lap time
bestTime = 0
setTickRate(30)
  -- rail values
  sxUpdateLinearGraph(timeDiff)
Boost Gauge
Assumptions
Script
setTickRate(30)
  local map = getChannel("MAP")
  --convert to PSI boost
  sxUpdateLinearGraph(boost)
ShiftX3 CAN bus API
Hardware / CAN configuration
CAN Base Address
Open 931584 (0xE3700)
CAN Baud Rate
ShiftX3 CAN baud rate setting
ADR2 jumper setting Baud Rate
Closed (Default setting) 500K
Open 1MB
ShiftX3 CAN Protocol
Offset What Value
Set Display
CAN ID: Base + 50
Offset What Value
0 Digit index 0 (must be 0)
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 20
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
CAN ID: Base + 21
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 22
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 41
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 42
Offset What Value
0 Value (low byte)
1 Value (high byte)
Notifications
Offset What Value
Offset What Value
Button State
CAN ID: Base + 60
Offset What Value
