ShiftX3
- ShiftX3
- ShiftX3
- RJ45 CAN hub
- Low profile RJ45 Cable
Dimensions
Compatibility
ShiftX3 is compatible with:
- RaceCapture/Track MK2
- RaceCapture/Pro MK2 and MK3
- RaceCapture/Apex
- PodiumConnect
Firmware Requirements
Connection and Installation
Mounting ShiftX3
- RJ45 Splitter
- RJ45 network cable
Non OBDII installation
- Note:
RJ45 power cable for ShiftX3
(Note, CAN 1 is not connected on ShiftX3, use CAN2 connection)
RJ45 pin # | RaceCapture Connection standard RJ45 pinout | CAT5 EIA-T568B RJ45 cable (into ShiftX3) |
8 | +12v | Brown |
1 | Ground | Orange/White |
N/C | CAN 1 High | Orange (No Connection to ShiftX3) |
N/C | CAN 1 Low | Green/White (No connection to ShiftX3)) |
4 | CAN 2 High | Blue |
5 | CAN 2 Low | Blue/White |
ShiftX3 Features
Disco Lights Demo
Script
Script
setTickRate(30) -- Set ShiftX3 configuration parameters with default parameters -- orientation: 0=normal, 1=inverted (display above LED bar) -- brightness: 0-100%, 0 = auto brightness -- can bus: 0=CAN1, 1=CAN2 sxSetConfig(0,0,1) --create gear channel gearId = addChannel("Gear", 10, 0, 0, 6) --config shift light sxCfgLinearGraph(0,0,0,7000) --left to right graph, smooth style, 0 - 7000 RPM range sxSetLinearThresh(0,0,1000,0,255,0,0) --green at 3000 RPM sxSetLinearThresh(1,0,5000,255,255,0,0) --yellow at 5000 RPM sxSetLinearThresh(2,0,6000,255,0,0,10) --red+flash at 6000 RPM function onTick() sxUpdateLinearGraph(getChannel("RPM")) -- calculate gear: tire diameter(cm), final gear ratio, individual gear ratios 1-6 local gear = calcGear(62.7, 3.45, 4.23, 2.52, 1.66, 1.22, 1.0, 0.8) setChannel(gearId, gear) sxSetDisplay(0, gear) end
Shift Light + Twin Alert + Gear Example
Assumptions:
- Gear channel is created with the channel name "Gear"
Script
setTickRate(30) -- Set ShiftX3 configuration parameters with default parameters -- orientation: 0=normal, 1=inverted (display above LED bar) -- brightness: 0-100%, 0 = auto brightness -- can bus: 0=CAN1, 1=CAN2 sxSetConfig(0,0,1) --config shift light sxCfgLinearGraph(0,0,0,7000) --left to right graph, smooth style, 0 - 7000 RPM range sxSetLinearThresh(0,0,1000,0,255,0,0) --green at 3000 RPM sxSetLinearThresh(1,0,5000,255,255,0,0) --yellow at 5000 RPM sxSetLinearThresh(2,0,6000,255,0,0,10) --red+flash at 6000 RPM --configure first alert (right LED) as engine temperature (F) sxSetAlertThresh(0,0,205,255,255,0,0) --yellow warning at 205F sxSetAlertThresh(0,1,225,255,0,0,10) -- red flash at 225F --configure second alert (left LED) as oil pressure (PSI) sxSetAlertThresh(1,0,0,0,0,255,10) --red flash below 15 psi sxSetAlertThresh(1,1,15,255,255,0,5) --yellow flash 15-20 PSI sxSetAlertThresh(1,2,20,0,0,0,0) --above 20, no alert --create gear channel gearId = addChannel("Gear", 10, 0, 0, 6) function onTick() --update RPM sxUpdateLinearGraph(getChannel("RPM")) -- calculate gear: tire diameter(cm), final gear ratio, individual gear ratios 1-6 local gear = calcGear(62.7, 3.45, 4.23, 2.52, 1.66, 1.22, 1.0, 0.8) setChannel(gearId, gear) sxSetDisplay(0, gear) --update engine temp alert sxUpdateAlert(0, getChannel("EngineTemp")) --update oil pressure alert sxUpdateAlert(1, getChannel("OilPress")) end
Script
Boost Gauge
Assumptions
Script
ShiftX3 CAN bus API
Hardware / CAN configuration
CAN Base Address
Open | 931584 (0xE3700) |
CAN Baud Rate
Closed (Default setting) | 500K |
Open | 1MB |
ShiftX3 CAN Protocol
Offset | What | Value |
Set Display
CAN ID: Base + 50
Set Discrete LED
CAN ID: Base + 10
2 | Red | 0 - 255 |
3 | Green | 0 - 255 |
4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
1 | Red | 0 - 255 |
2 | Green | 0 - 255 |
3 | Blue | 0 - 255 |
Set Alert Threshold
CAN ID: Base + 21
1 | Threshold ID | 0 - 4 |
2 | Threshold (low byte) | |
3 | Threshold (high byte) | |
4 | Red | 0 - 255 |
5 | Green | 0 - 255 |
6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
1 | Value (low byte) | |
2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
2 | Low Range (low byte) | |
3 | Low Range (high byte) | |
Set Linear Graph Threshold
CAN ID: Base + 41
0 | Threshold ID | 0 - 4 |
4 | Red | 0 - 255 |
CAN ID: Base + 42
0 | Value (low byte) | |
1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
