MJLJ V4 vehicle installation guide
Parts you will need
    • EDIS-8 for 8 cylinder
    • EDIS-6 for 6 cylinder
    • EDIS-4 for 4 cylinder
EDIS installation
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
MJLJ Connector Pinout
File:MJLJ V4 connector pinout.png
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Using EDIS PIP signal
Smiths RVI type tachometers
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
