How To Update Firmware
Revision as of 15:13, 8 April 2019 by Brentp (talk | contribs)
Firmware upgrade steps
Applies to:
  • RaceCapture/Pro MK3 and MK2
  • RaceCapture/Apex
  • PodiumConnect
  • RaceCapture/Track MK2 and MK1
Save your configuration
Download the firmware
  • Note Ensure you download the correct firmware for your device (matching the product name), or the firmware process will fail to complete.
Flash the firmware
  • Note: Flashing is only possible via the USB interface, so you must use the desktop version of the RaceCapture app.
Steps
Updating Firmware
  • Unzip the firmware your downloaded to a location on your computer.
  • Connect your system to your Windows or OSX computer using the included USB cable.
  • Navigate to the Setup view
  • Browse to the unzipped firmware from the first step. Select the file ending with ".ihex" - and press Open
  • Restore your saved configuration by pressing the Open button, selecting your saved configuration, and then Write it to your system.
Alternative method
Problems? Post to the forums with the issue you're seeing - we will help you promptly.
RaceCapture/Pro MK1
Alternatively:
Mac Users
