RCP stimulator
Connect the stimulator to the RaceCapture/Pro inputs using the following diagram.
  • You can provide power + ground to RCP using the 12v and Ground outputs on the Stimulator. The power and ground on the RCP will not provide power or ground to the Stimulator. The Stimulator needs its own power.
  • The power plug is a 5.5x2.5mm. A 5.5x2.1 will also work.
  • You can use a 5V USB adapter to power it, however it may not have enough power to also power the RCP. If using 5V USB to power the Stimulator, you will also need to plug the RCP into USB to power the RCP seperately.
  • Here is a cheap 5V USB power adapter that will work with the Stimulator. https://amzn.to/2XwSF1w
  • RCP MK3 plug is a standard 24 pin Molex ATX computer power plug. You can buy an ATX extension cable for $7. Cut the cables in half and wire the male end to the Stimulator terminal blocks. You could then use the female end to make an adapter to go from RCP MK3 molex to RCP MK2 20 pin terminal block. This would allow you to use your Stimulator for both MK3 and MK2 RCP's.
  • Do not connect the stimulator's 5v output to the 5v VREF output on RaceCapture/Pro; it is only provided for reference.
  • The AUX TX/ RX line needs to be connected in the following fashion so data can flow correctly:
    • Stimulator AUX_TX -> RCP AUX_RX
    • Stimulator AUX_RX -> RCP AUX_TX
  • CAN bus 1 and 2 are bridged together; you can disable this by breaking the PCB jumpers on the bottom side of the board, near terminal block, using a razor knife or a very small screwdriver
  • You can download a preset config file for the Stimulator here: File:RCP Stimulator MK3.zip
  • The blue 5 pin female and 6 pin male headers are for programming the microcontroller. The button between them is for putting the microcontroller into bootloader mode. Do not use these unless instructed to.
Analog outputs
RPM/Pulse outputs
4 Pulse outputs are provided to stimulate up to 4 RPM/Pulse inputs. The pulse outputs work well for simulating a low (420) to high (10,000) RPM range using the following RPM channel settings:
  • 1 pulse per revolution
  • Medium Speed timer channel
  • RPM mode
GPIO
Input Mode
Output mode and Demo script
  • Note Ensure the GPIO ports are in output mode under RaceCapture Setup / Digital In/Out.
--Demo script for toggling LEDs on stimulator board
--GPIOs must be set for output mode in RaceCapture Setup
setTickRate(1)
count = 0
  --toggle LEDs
  local state = count % 2
  setGpio(0, state == 0)
  setGpio(1, state == 0)
  setGpio(2, state == 0)
  count = count + 1
CAN bus output
4 knobs control the value of 4 CAN channels. These channels are broadcast on CAN ID 276. The baud rate is 500k:
  • Channel 1: Offset 0, length 2
  • Channel 2: Offset 2, length 2
  • Channel 3: Offset 4, length 2
  • Channel 4: Offset 6, length 2
The CAN data is broadcast as a raw value between 0-10000 and can be scaled further using the CAN channel mapping.
Note:
Baud Rate
Baud rate is 115200, 8N1
Format
  • Timestamp in milliseconds
  • Channel 1 value (0-10000)
  • Channel 2 value (0-10000)
  • Channel 3 value (0-10000)
  • Channel 4 value (0-10000)
  • Value echoed back from received data
initSer(6, 115200, 8, 0, 1)
  writeSer(6, 'echo')
  value = readSer(6, 1000)
    print('read value: ' ..value)
352023 ,0,0,0,0,echo
352223 ,0,0,0,0,echo
352423 ,0,0,0,0,echo
352623 ,0,0,0,0,echo
352823 ,0,0,0,0,echo
353023 ,0,0,0,0,echo
353223 ,275,0,0,0,echo
353423 ,1680,0,0,0,echo
353623 ,1680,0,0,0,echo
353823 ,1680,0,0,0,echo
354023 ,1672,0,0,0,echo
354223 ,1697,1181,0,0,echo
354423 ,1699,2666,0,0,echo
354623 ,1704,2649,0,0,echo
354823 ,1706,2656,0,0,echo
355023 ,1692,2647,0,0,echo
355223 ,1728,4554,0,0,echo
355423 ,1724,4595,0,0,echo
355623 ,1741,4588,0,0,echo
355823 ,1753,4590,1199,0,echo
356023 ,1750,4588,1323,0,echo
356223 ,1755,4588,4730,0,echo
356423 ,1750,4588,4984,0,echo
356623 ,1758,4586,4981,0,echo
356823 ,1750,4583,4959,1299,echo
357023 ,1758,4586,4964,4129,echo
357223 ,1758,4588,4947,4473,echo
357423 ,1753,4586,4957,5269,echo
357623 ,1753,4586,4957,5768,echo
