Raspberry Pi Tips
UNDER CONSTRUCTION
Choose the fastest MicroSD card you can for fastest boot times. 32gb is plenty big and reasonably cheap, Class 10 is preferred. I used this one:
On a computer, format the card with FAT32 Download the latest Raspberry Pi Image to the PC
Write the image to the SD card using Win32DiskImager
Start Pi and Update OS
  • Place the MicroSD card in the Pi, connect a LAN cable to the Pi's Cat5 connection for internet access, and power up.
  • You will be asked to login to the device:
    • pispberrypi login: pi
    • Password: raspberry
  • Once you have a blinking command line prompt, update to the latest packages:
sudo apt-get update
sudo apt-get dist-upgrade
  • You will be asked if you would like to continue, press "Y" and press enter
  • Once the upgrade is done, clean the upgrade junk
sudo apt-get clean
sudo raspi-config
  • Choose Desktop/CLI as Pi
  • Highlight #4 Localisation Options and hit enter. I live in the Eastern Timezone of the US - customize this to your location.
    • Choose I1 Change Locale
    • Hit enter
sudo nano /boot/cmdline.txt
  • Inside this file, make the following changes:
    • Append the following to the end of the line:
sudo nano /boot/config.txt
Add the following line to the bottom of the file:
disable_splash=1
When you need to use the internet to update Pi or RaceCapture, simply enable and start the same services.
General Notes and Commands
  • Run Racecapture manually
  • Make cursor visible (if desired) - may cause lag in dashboard so not recommended except for setup*
cursor = 1
  • Exit RaceCapture
  • Manually shutdown pi
Sudo Shutdown -h now
  • Rotate screen 180*
  • This just rotates display, not touch
  • Add this line:
display_rotate=2
  • Rotate touch for RaceCapture
Modify this line:
Change keyboard to US
cd /opt
sudo tar -xjvf race...
Setup for Mausberry circuit
sudo bash carsetup.sh
sudo reboot
sudo nano /etc/rc.local
  • Reboot to take effect.
sudo reboot
Set up for DFRobot display
  • Uncomment this line:
disable_overscan=1
  • Add this line:
hdmi_cvt 1024 600 60 6 0 0 0
hdmi_group=2
hdmi_mode=87
Cd /opt/racecapture/
Sudo nano run_racecapture.sh
  • Comment out both checks for "check for ar1100 resistive touch" and "check for ft5406 capacitive touch"
  • Change kivy settings:
[input]
mouse = mouse
