Raspberry Pi Tips
- Choose the fastest MicroSD card you can for fastest boot times. 32gb is plenty big and reasonably cheap. Class 10 is preferred. I used this one:
- On a computer, format the card to FAT32 format
- Download the latest Raspberry Pi Image to the computer
Start Pi and Update OS
- Place the MicroSD card in the Pi, connect a LAN cable to the Pi's Cat5 connection for internet access, connect a keyboard, monitor, (and mouse if you wish), then power up.
- Login: pi
- Password: raspberry
sudo apt-get clean
sudo raspi-config
- Choose Desktop/CLI as Pi
- Choose I1 Change Locale
- Hit enter
sudo nano /boot/cmdline.txt
sudo nano /boot/config.txt
disable_splash=1
Change keyboard to US
cd /opt
sudo tar -xjvf race...
Setup for Mausberry circuit
sudo nano /etc/rc.local
- Reboot to take effect.
sudo reboot
Set up for DFRobot display
- Uncomment this line:
disable_overscan=1
- Add this line:
hdmi_cvt 1024 600 60 6 0 0 0
hdmi_group=2 hdmi_mode=87
- Comment out both checks for "check for ar1100 resistive touch" and "check for ft5406 capacitive touch" by putting a # symbol at the front of the line
- Change kivy settings:
General Notes and Commands
Run Racecapture manually
- If you don't set it up to run automatically, you'll have to use this command to run it manually.
Make cursor visible
- This may cause lag in the dashboard so it's not recommended except for setup if you elect to use a mouse
cursor = 1
Exit RaceCapture
Manually shutdown pi
Sudo Shutdown -h now
Rotate screen 180*
- This just rotates the display, but does not rotate the touch settings
- Add this line:
display_rotate=2
- If you have a touch screen, you will need to rotate the touch settings for RaceCapture
- Modify this line:
