AnalogX
Revision as of 18:00, 12 January 2020 by Brentp (talk | contribs) (→Power and CAN)
In the kit you will receive:
  • AnalogX module
Compatible Sensors
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Sensor Conversion Formulas
The Autosport Labs Linear Fluid Temperature sensor has a 10mV/C scaling, with a 0.5V offset at 0C.
150 PSI pressure sensor
Therefore, 150 PSI / 4000mV = 0.0375 PSI/mV
Other sensors
No CAN data
  • Verify the CAN baud rate is compatible with the AnalogX configuration (500K by default, 1MB with jumper modified)
  • Verify your CAN bus termination is correct. AnalogX is terminated by default.
Basic mapping test
Feature Description
DAC resolution 12 bit SAR
Input voltage protection 100v
Harness 26 gauge leads for power, ground, CAN and sensor inputs
Weight 6 grams
Source Code
Power and CAN
Pin 1 is on left when facing board connector
Pin Assignment Notes
1 9-15v Power Connect this to switched ignition power. 0.25A max consumption.
2 CAN High
3 CAN Low
4 Ground
Sensor connections
Pin 1 is on left when facing connector
1 Analog 1 input 0-5v input
2 Analog 2 input 0-5v input
3 Analog 3 input 0-5v input
4 Analog 4 input 0-5v input
5 Voltage reference output (for powering sensors) 5v @ 0.5A
6 Ground reference
CAN termination
  • Note: Use a razor or very fine tipped screwdriver to break the bridge on the pad, scraping towards the outside of the circuit board. To re-enable the bridge, solder across the pads using a low wattage (15-30W) soldering iron to prevent damage to the pads.
AnalogX CAN bus API
Adjusting Base ID
Closed Open 0xE4700 (935680)
Open Closed 0xE4800 (935936)
Open Open 0xE4900 (936192)
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Group 1
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Sample Broadcast
Scaling and Data format
  • Scaling: 0-5000mV
  • Data format: Little Endian
Address
  • CAN ID: Base + 20
Offset What Value
0 Channel 1, low byte
1 Channel 1, high byte
2 Channel 2, low byte
3 Channel 2, high byte
4 Channel 3, low byte
5 Channel 3, high byte
6 Channel 4, low byte
7 Channel 4, high byte
