TireX
Revision as of 23:19, 18 March 2020 by Brentp (talk | contribs)
Feature Description
Sensor type Thermal array
Object temperature range -40 - 200C
Accuracy 1C
Temperature zones 1 / 2 / 4 / 8 / 16
Sample rate 0.5 - 64Hz
Temperature compensation Automatic
Electrical
Supply voltage 6 - 12v
Power 200mW
Address space 4 separate address spaces (jumper configurable)
Termination No Termination (jumper configurable)
Physical / Environmental
Dimensions 64 x 46 x 12.5mm
Weight 10 grams
Operating temperature -40 to 85C
IP rating IP65
CAN bus protocol reference
