TireX
Upcoming Product
TireX pre-orders are starting soon: sign up to get notified when pre-orders launch
High Performance
Rugged and Compact
Flexible Setup
  • CAN bus can be set for 500 or 1MB (default is 500K)
Feature Description
Sensor type Thermal array
Object temperature range 0 - 127.5C (-40 - 300C range available via special order)
Field of view 120 degrees
Accuracy 1C
Temperature zones 1 / 2 / 4 / 8 / 16
Sample rate 0.5 - 64Hz
Processing Engine 32 bit
Temperature compensation Automatic
Electrical
Interface CAN 2.0
Supply voltage 6 - 12v
Power 200mW
Physical / Environmental
Construction CNC aluminum
Dimensions 64 x 46 x 12.5mm
Weight 10 grams
IP rating IP65
Dimensions / Mounting
Electrical / CAN connection
Pin Connecton
Pin 1 CAN Low
Pin 2 Voltage supply (6-12v)
Pin 3 CAN High
Pin 4 Ground
Zone Configuration
When configured for 2 or more zones, temperature for zones are reported in the order of inside through outside edge. TireX zones are reversed based on the configured sensor position (left vs right side) to allow identical physical sensor mounting orientation between sides.
Zones Coverage
CAN bus protocol
Formula
  • Example:
    • Formula: A / 100
    • Real-world value: 0.95
Data encoding
Endian
Single and mulit-byte values
Value Symbol Reference
8 Bit values A
Default Main Base ID
Adjusting Main Base ID
Closed Closed 0xA100 (41216)
Closed Open 0xB100 (45312)
Open Closed 0xC100 (49408)
Open Open 0xD100 (53504)
Sensor Position Offset
0 Left-Front 0x0 (0)
1 Right-Front 0x100 (256)
2 Left-Rear 0x200 (512)
3 Right-Rear 0x300 (768)
Left-Front 0xA100
Right-Front 0xA200
Left-Rear 0xA300
Right-Rear 0xA400
CAN ID: Sensor Base ID + 0
3 Reserved
4 Reserved
CAN ID: Sensor Base ID + 2
0 Current Sample Rate unsigned A * 1 0.5 - 64Hz (0 = 0.5Hz)
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Preferences
CAN ID: Sensor Base ID + 3
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Calibration Preferences
CAN ID: Sensor Base ID + 4
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Sensor Value Broadcast
The following messages will contain the temperature values based on the number of temperature zones selected.
1 Zone
2 Zones
4 Zones
8 Zones
16 Zones
