RaceCapture on Raspberry Pi
Benefits
Compatibility
Experimental!
Hardware Selection
Raspberry Pi
Display
Enclosure
Installed on Dashboard
Power Supply
To power everything, you'll need a high quality 5v power supply with 2 amps minimum capacity; 3 amps is highly recommended, and one with a low drop out voltage, so power is not cut to the Raspberry Pi when you're loading the main battery, such as when cranking the engine.
You'll preferably want one designed to be hard wired into your car for maximum reliability.
Suggested Power Supplies:
Heat sinking
Installing Rasbian OS
Installing dependencies
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
- Via raspi-config tool
- Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture.sh
Automatic start upon power up
sudo nano /etc/rc.local
Powering up
- Launch the RaceCapture app by running:
Connection and usage
Extra Features
Hardwire buttons
- N : to indicate 'No"
Additional Tips
