MJLJ V4 kit assembly guide
Revision as of 07:32, 11 June 2008 by Brentp (talk | contribs) (remove pic resizing)
Precautions
Surface mount Components
Before you Begin
Familiarize
Do not lose parts
Lighting
Note part orientation
Do not overheat
Assembling the kit
Tools you will need
Parts Inventory
Core Parts
Part Type Value Photo
PC Board MJLJ V4 PC Board
Enclosure MJLJ V4 Enclosure File:MJLJ V4 enclosure.jpg
R1,R7 Resistor 100 ohms
R2,R8 Resistor 1K
R5,R6 Resistor 2.2K
R9 Resistor 680 ohm
D6,D7 Schottky Diode
C15 Capacitor 0.001uF
C16 Capacitor 0.22uF
D4 Diode 12V Zener
U1 Integrated Circuit MJLJ V4 Processor Freescale MC908QB8 File:MC908QB8.jpg
IC1 Integrated Circuit ULN2003 Transistor Array File:ULN2003.jpg
U2 Integrated Circuit MAX232A Transceiver (or equivalent) File:MAX232a.jpg
IC1,U1 Sockets 16 Pin DIP Socket File:PDIP-16 socket.jpg
X1 Connector RJ-11 jack File:RJ11 jack.jpg
Pins Molex Pins (16)
TPS Option
R3 Resistor 1K
C11 Capacitor 0.1uF
C12 Capacitor 0.001uF
C13 Capacitor 0.22uF
C14 Capacitor 15uf
D5 Diode Schottky Diode
L1 Inductor 1uH
MAP Sensor Option
R4 Resistor 270 ohm
C8,C9 Capacitor 0.1uF
PS1 Sensor MPX4250ap File:MPX4250ap.jpg
Fastener Zip Tie
Surface Mount Parts
Power supply Circuit
Prepare solder pads
Components
  • D4: 12V Zener diode. Note stripe orientation: The silk-screened arrow on the PC board points towards the stripe.
If you have difficulty identifying them, increase the lighting- bright lighting is essential.
  • R9: 680 ohm resistor
Testing Voltages
  • U1
  • U2
  • IC1
  • QG1
  • PS1
Main Circuit
Prepare Solder Pads
Components
  • D6,D7: Schottky diode (strip of two diodes, SOD-123 package
MAP sensor option
  • C9,C8: 0.1uF capacitor (strip of 6 capacitors, ORANGE stripe on tape)
TPS option
  • D5: Schottky Diode (strip of one diode, SOD-123 package )
  • C14: 15uF capacitor (grey tantalum package)
Testing Voltages
  • U1
  • U2
  • IC1
  • QG1
  • PS1
Through Hole Parts
IMPORTANT: It extremely important you install the through-hole components with the correct orientation! De-soldering a backwards-installed component is extremely difficult and will likely damage the board. GET IT RIGHT THE FIRST TIME!
Install Components
You may need to re-heat the pad while squeezing the part against the board. Once your
If not perfect, re-heat solder near the corner affected and correct the connector's position.
MAP Sensor Option
Testing Voltages
  • U1
  • U2
  • IC1
  • QG1
  • PS1
Installing ICs
Install U1- MJLJ V4 Processor Freescale MC908QB8. Note notch orientation Install IC1- ULN2003 transistor array Note notch orientation
Final Inspection
Solder joints
Carefully check the top and bottom of board for solder joint quality- all joints should be bright and shiny, minimal blobbing, no solder 'spikes', bridges. Also look for missed solder joints!
Part placement
Ensure all through hole components are flush
TIP: An illuminated magnifying glass is great for getting an up-close inspection of your work
Enclosure installation
TIP: the molex connector is slightly off-center, so it's easier to use install the plate with the board installed first.
Testing
Verification on the bench
Next Steps
