AnalogX2
Revision as of 22:27, 10 January 2021 by Brentp (talk | contribs)
In the kit you will receive:
  • AnalogX2 module
Harness / Cabling
SKU Description
ASL_M8_CAN_EXT_0.5M
ASL_M8_CAN_EXT_1M
ASL_M8_CAN_EXT_2M
ASL_M8_CAN_EXT_3M
ASL_M8_CAN_EXT_4M
CAN extension cable, M8 4P female to M8 4P male, 0.5 - 4 Meter lengths
Sensor Connections
SKU Description
ASL_M8_SENSOR_EXTENSION_1M
ASL_M8_SENSOR_EXTENSION_2M
ASL_M8_SENSOR_EXTENSION_3M
ASL_M8_SENSOR_EXTENSION_4M
Bare pigtails
For a custom or non-plug and play installation, these bare pigtail cables are available:
SKU Description
Compatible Sensors
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Sensor Conversion Formulas
(0 - 10 bar / 150 PSI range)
  • 0.5v 0 bar / = 0 PSI
  • 4.5v = 10 bar / 150 PSI
Therefore,
  • Note:: The 0.375 value was derived from the formua: 150 PSI / 4000mV = 0.0375 PSI/mV
  • 0.5v = 0 bar / 0 PSI
  • 4.5v = 150 bar / 2175 PSI
Other sensors
Power and CAN
Pin Connection Notes
1 CAN low
2 Power Red, 12-14v / 50mA
3 CAN high
4 Ground Black
Sensor connections
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
DIP switch settings
Switch Function Description
CAN termination
No CAN data
Basic mapping test
Feature Description
DAC resolution 12 bit SAR
Input voltage protection 100v
Weight 5 oz (approximately)
Environmental IP65, 0-85C
AnalogX CAN bus API
Adjusting Base ID
Off Off 0xE4600 (935424)
Off On 0xE4700 (935680)
On Off 0xE4800 (935936)
On On 0xE4900 (936192)
1M is enabled by default; switch on the Baud DIP swith to enable 500K data rate.
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Group 1
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Sample Broadcast
Scaling and Data format
  • Scaling: 0-5000mV
  • Data format: Little Endian
Address
  • CAN ID: Base + 20
Offset What Value
0 Channel 1, low byte
1 Channel 1, high byte
2 Channel 2, low byte
3 Channel 2, high byte
4 Channel 3, low byte
5 Channel 3, high byte
6 Channel 4, low byte
7 Channel 4, high byte
