RaceCapture on Raspberry Pi
Benefits
Compatibility
Experimental!
Hardware Selection
Raspberry Pi
RaceCapture currently requires the Raspberry Pi 3: Raspberry Pi 3.
It is not yet compatible with the Pi 4, due to extensive changes in the graphics subsystem. Expect to see Pi 4 support in the 2.0 version of the app.
Display
Enclosure
Installed on Dashboard
Power Supply
Suggested Power Supplies
Powering RaceCapture
Heat sinking
Installing Rasbian OS
Updating to latest packages
Raspberry Pi support
The RaceCapture app is compatible with Raspberry Pi 4 and 3.
Raspberry Pi 4 Notes
Raspberry Pi 4 support is only available with the V2 Beta app, see our Discord channel to access testing.
Raspberry Pi 3 Notes
Enable Fake KMS under advanced boot options:
sudo raspi-config
Go to Advanced Options -> GL Driver -> Select OpenGL desktop driver with fake KMS
- Be sure to reboot after exiting raspi-config
Installing dependencies
Activate ssh
Ssh is used to store passwords used by the app. Steps to ensure it is running:
sudo raspi-config
Go under Advanced Options and start the ssh service.
Next, at the command prompt enter
ssh-add
to create at least one key.
Install package dependencies
sudo apt-get install mesa-utils libgles2 libegl1-mesa libegl-mesa0
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
- Via raspi-config tool
- Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture
Automatic start upon power up
sudo nano /etc/rc.local
Powering up
- Launch the RaceCapture app by running:
Connection and usage
Extra Features
Hardwire buttons
- N : to indicate 'No"
Additional Tips
