Install ubuntu 22.x
- Select Automatic Login without password
Disable keyring popup
Install dependencies
sudo apt-get install v4l-utils tk gstreamer1.0-plugins-bad gstreamer1.0-libav gconf2
Enable access to RaceCapture serial port
sudo adduser $USER dialout
sudo echo "ATTRS{idVendor}==16d0, ATTRS{idProduct}==07f1, MODE=0666" | sudo tee /etc/udev/rules.d/70-autosportlabs.racecapture.rules
Hide Ubuntu Top bar
Hide side bar
sudo apt install gnome-shell-extensions
Now run extensions tool, set Ubuntu Dock -> OFF
Disable system update notification poupup
gconftool -s --type bool /apps/update-notifier/auto_launch false
Download the latest RaceCapture app for Linux
Extract the RaceCapture app archive
tar -xzf <downloaded filename>
Launch RaceCapture app
./run_racecapture_linux.sh
Enable fullscreen mode & Default dashboard mode
- Go to Setup / App Preferences
- set Fullscreen -> ON
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
