RaceCapture on Raspberry Pi
Benefits
Compatibility
Experimental!
Hardware Selection
Raspberry Pi
The RaceCapture app is compatible with Raspberry Pi 4 and 3. We recommend the Raspberry Pi 4 2GB and higher for best performance and support.
Display
Enclosure
Installed on Dashboard
Power Supply
Suggested Power Supplies
Powering RaceCapture
Heat sinking
Installing Raspberry Pi OS
We currently recommend Raspberry Pi OS Lite, Debian Version 11 (bullseye) and require a 64bit version for app versions 2.9.0 and newer.
Download from the official site or use the Raspberry Pi imager, following the instructions for burning to an SD card.
Once you've created your image, boot up your Raspberry Pi and follow the prompts to set your keyboard language and create a username and password.
You should now be able to login as that user and will be greeted with a command prompt like `user@raspberrypi:~ $`
Wifi Setup
Timezone
It is advisable to set the system's timezone before proceeding. This is also accomplished by using raspi-config which is run with the command `sudo raspi-config`. If you are also setting up Wifi you can configure your timezone at the same time you are configuring Wifi.
The timezone setting is configured in `5 Localization Options`->`L2 Timezone`. This will allow you to set the timezone by first selecting your region and a major city in your timezone. When done setting the timezone you can back out of raspi-config by hitting escape until you are back at the command prompt.
Checking your network
At this point it is good to make sure your Raspberry Pi is connected to your network. Without this none of the remaining steps will be successful.
Updating to latest packages
RaceCapture App Installation
If you want a more custom installation, such as running in a full Desktop environment, manual instructions are also provided.
Via Installation Script
From a command prompt simply run
sudo sh -c "curl -sL bit.ly/3yTbPyZ | bash"
Configuration Options
The installation script prompts for the following:
Auto Login
RPi3 Official Display Support
Installation Type
- If X11 was chosen:
App Features
Extra Features
Post Configuration Steps
Next it will unpack the App into /opt/racecapture, prompting you to overwrite and existing installation if one exists.
Finally, the script will modify some files, .bashrc and .xinitrc for X11 installations, so that the Race Capture app launches upon login.
Manual Installation
Install package dependencies
sudo apt install mesa-utils libgles2 libegl1-mesa libegl-mesa0 mtdev-tools
User Permissions
Ensure that the user is in the dialout, render, video and input groups. It appears these are added by default but to be sure you should run:
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture
Enabling on screen keyboard
Edit the kivy config.ini file with:
sudo nano ~/.kivy/config.ini
and update the keyboard_mode line with:
keyboard_mode = multi
Powering up
Installed via Script
Manual Installation
See #Launch_the_app
Connection and usage
Extra Features
Hardwire buttons
- N : to indicate 'No"
Additional Tips
Logfiles for troubleshooting can be found at
/home/pi
