Revision as of 15:34, 24 April 2023 by Brentp (talk | contribs) (→Log out)
Setup
Install ubuntu 22.x
  • Select Automatic Login without password
Disable keyring popup
Disable the keyring popup
Run the installer
Reboot
Reboot the computer. It should automatically launch the RaceCapture app.
Edit RaceCapture settings
App Preferences
In the RaceCapture app, go to Setup / App Preferences:
  • set Fullscreen -> ON
  • Turn off Session Recording
Dashboard Preferences
Go to Dashboard, then press the gear icon in the upper right of the dashboard. Touch More Settings
  • Turn off Pit stop timer
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Video Streaming / recording
TODO: update this section with information on configuring the youtube streaming key, etc.
Video will be recorded in the user's home Video directory.
Maintenance/Troubleshooting
Open a terminal window
  • Press ctrl+t then c
Log out
  • Press ctrl_t then :
