Revision as of 20:31, 10 May 2023 by Brentp (talk | contribs) (→Cameras)
  • Local video recording
Cost
How hard is it to setup?
  • Typing computer commands
  • Plugging in cables
  • Editing configuration files
System Diagram
Parts you will need
Compatible Systems
Rendering/Streaming computer
Recommended
Alternatives
  • Look for these options:
Candidates
12v DC to DC converter
  • Tips:
Recommended
  • Notes:
Cameras
Alternatives
  • Tips:
Microphone
  • Candidates:
Hotspot/Router
Setup
Install ubuntu 22.x
Disable keyring popup
From the desktop, choose log out, and log back in with the password you created during the installation step.
  • Note: Disabling the keyring is important to prevent a popup dialog when the RaceCapture app automatically starts.
Run the installer
Reboot
Edit RaceCapture settings
App Preferences
  • set Fullscreen -> ON
  • Turn off Session Recording
Dashboard Preferences
  • Turn off Pit stop timer
Plug in camera(s)
Plug in USB microphone
Configure Dashboard
Create a test dashboard
Video Streaming / recording
Streaming Key / URL
Local recording
Microphone
Example default config file
[capture]
audio_device=1
[local_recording]
video_dir=$HOME/Videos
[streaming]
Maintenance/Troubleshooting
Open a terminal window
  • Press ctrl+t then c
Log out
  • Press ctrl_t then :
