- Rich graphics overlay in realtime
- Local video recording
Cost
How hard is it to setup?
- Typing computer commands
- Plugging in cables
- Editing configuration files
Is it reliable?
Since it is based largely on existing RaceCapture systems (RaceCapture hardware and RaceCapture app), the core of the system is very stable.
However, newer components that facilitate video rendering, encoding, and streaming will receive more testing/debugging/fixing.
Experimental
With your testing help we can incrementally improve the system and ultimately provide an incredibly cost effective yet very full-featured and high performance system that rivals solutions costing upwards of $5000 USD.
System Diagram
Parts you will need
Compatible Systems
Rendering/Streaming computer
Recommended
Alternatives
- Look for these options:
Candidates
12v DC to DC converter
- Tips:
Recommended
- Notes:
Cameras
Alternatives
- Tips:
Microphone
- Candidates:
Hotspot/Router
Setup
Install ubuntu 22.x
- Install Ubuntu with the following options:
- During installation, choose the option to download / install updates, including "non-free" software updates (which includes video drivers)
- Select Automatic Login without password.
Disable keyring popup
- Notes
- This step is important to prevent a popup dialog when the RaceCapture app automatically starts.
Run the installer
Reboot
Edit RaceCapture settings
App Preferences
- set Fullscreen -> ON
- Turn off Session Recording
Dashboard Preferences
- Turn off Pit stop timer
- Turn off pit-to-car alerts
Plug in camera(s)
Plug in USB microphone
Connect RaceCapture
Your current RaceCapture system already supports multiple connections, so you can continue using your dashboard (e.g. Android tablet via Bluetooth) when adding this video+data streaming capabilities.
Supported connection options
Via USB (overall best option)
Via WiFi
Configure as Client
Create a test dashboard
Exiting the RaceCapture app
Video Streaming / recording
Streaming Key / URL
Local recording
Microphone
- Note, you can change this to different sources:
- 0 = built-in analog audio mic
- 1,2,3... - represents additional microphones found on the system, typically USB microphones.
Example default config file
[capture] audio_device=1 [local_recording] video_dir=$HOME/Videos [streaming] streaming_url=rtmp://a.rtmp.youtube.com/live2/<streaming key>
First Test
Maintenance/Troubleshooting
Open a terminal window
- Press ctrl+t then c
Log out
- Press ctrl_t then :
- Type 'quit' and press <enter>
Inspecting Logfiles
Video streamer log file
RaceCapture log file
