  • Local video recording
System Overview
Cost
How hard is it to setup?
  • Typing computer commands
  • Plugging in cables
  • Editing configuration files
Production State
A demonstration
Experimental
Parts you will need
Compatible Systems
Rendering/Streaming computer
Recommended
Alternatives
  • Look for these options:
Candidates
12v DC to DC converter
  • Tips:
Recommended
  • Tips:
Cameras
Autosport Labs will soon provide a camera kit that provides high quality imaging, a waterproof compact form-factor, and the perfect 90 degree field of view.
Alternatives
  • Tips:
Microphone
  • Candidates:
Display Emulator
Hotspot/Router
Setup
Install ubuntu 22 LTS
OS configuration options
    • Select Login Automatically
Disable keyring popup
  • Notes
Run the installer
sudo apt install curl
Reboot
Edit RaceCapture settings
App Preferences
  • set Fullscreen -> ON
  • Turn off Session Recording
Dashboard Preferences
  • Turn off Pit stop timer
  • Turn off pit-to-car alerts
Plug in camera(s)
Plug in USB microphone
Connect RaceCapture
Via USB (overall best option)
Via WiFi
Configure as Client
Create a test dashboard
Exiting the RaceCapture app
Video Streaming / recording
Streaming Key / URL
Local recording
Video files will also be saved in the user's Videos directory
Microphone
  • Note, you can change this to different sources:
    • 0 = microphone connected to built-in headset port;
    • 1,2,3... = represents additional microphones found on the system, typically USB microphones.
Example default config file
[capture]
audio_device=1
[local_recording]
video_dir=$HOME/Videos
[streaming]
First Test
Maintenance/Troubleshooting
Open a terminal window
Log out
Inspecting Logfiles
Video streamer log file
RaceCapture log file
Extras
Mount for Beelink micro PC
