How To Update Firmware
Revision as of 04:33, 3 July 2023 by Brentp (talk | contribs) (→‎Updating Firmware)
Firmware upgrade steps
Applies to:
  • RaceCapture/Pro MK4, MK3, and MK2
  • RaceCapture/Apex
  • PodiumConnect MK2 and MK1
  • RaceCapture/Track MK3, MK2, and MK1
Save your configuration
Download the firmware
  • Note Ensure you download the correct firmware for your device (matching the product name), or the firmware process will fail to complete.
Flash the firmware
  • Note: Flashing is only possible via the USB interface, so you must use the desktop version of the RaceCapture app.
Steps
Updating Firmware
  • Unzip the firmware your downloaded to a location on your computer.
  • Connect your system to your Windows or OSX computer using the included USB cable.
  • Navigate to the Setup view
    • Note: - If the RaceCapture app cannot read the configuration, you may need to first Open a previously saved configuration so you can access the firmware page.
  • Browse to the unzipped firmware from the first step. Select the file ending with ".ihex" - and press Open
  • Restore your saved configuration by pressing the Open button, selecting your saved configuration, and then Write it to your system.
  • If there is a problem detecting the system after firmware upgrade, unplug/replug your device and restart the app.
Alternative method
  • Navigate to Setup.
  • Load a previously saved configuration file.
  • Navigate to the firmware update view, then follow the process to update firmware.
Issues
  • If the firmware fails part way through, you can retry the firmware upgrade.
    • Start the app
    • Connect your device via USB
    • Load a previously saved config file (file ending in .rcp)
    • Navigate to Setup / Firmware
    • Attempt the firmware upgrade process again.
RaceCapture/Pro MK1
Alternatively:
Mac Users
