RaceCapture-Pro MK4S Sensors
Delphi-Style
  • Connection Size : 1/8″ NPT
  • Cable length : 1 Meter
  • Voltage supply : 3-5V
[ Wells SU109 : Engine Coolant Temperature Sensor ]
Pressure Sensors
Pulse/Speed/RPM Sensors
Distance Sensors
Angle/Rotation Sensors
Air / Fuel Ratio Sensors
Wiring Analog Sensors
