RaceCapture-Pro MK4S Sensors
GM-Style
- Thread Size : 1/8″ NPT
- Cable length : 1 Meter
- Voltage supply : 3-5V
- Thread Size : 3/8" NPT
- Cable length : N/A
- Body Material : Copper
- Pigtail :Pico 5616pt
- Body Material : Brass
Delphi-Style
- Voltage supply : 5V
Pressure Sensors
Fluid Pressure
- Cable length : 2 Meter
- Mfg / Prt : AEM 30-2131-150
- Mfg / Prt : 12223861 (GM)
- Output : 0.2 to 4.9 V
- Use : An extremely popular MAP sensor used in the Megajolt ignition and Megasquirt fuel injection systems.
Pulse/Speed/RPM Sensors
- Mfg / Prt : ASL_COILX
